The Truth about Exhaust Wrap??
Old 10-13-2009, 09:25 AM
reesestewww's Avatar
reesestewww
reesestewww is offline
Question The Truth about Exhaust Wrap??
I’ve been reading threads for a couple weeks across all the forums here regarding exhaust/pipe wrap with what seems to be many different opinions. I’d like to wrap my pipes on my SB (up to the mufflers) in a black wrap, keeping the chrome mufflers exposed. What kind of results should I expect in regards to heat from the pipes? Will I feel an increase, decrease or the same amount of heat with the wrap vs. the OEM heat shield?
Thanks
R
Old 10-13-2009, 09:36 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
it will be about the same man to be honest... they just change the look more than anything unless you have a high performace motor
here is what mine looked like set up that way
after i cut heat shields for it
Old 10-13-2009, 09:52 AM
thedonthere's Avatar
thedonthere
thedonthere is offline
No difference than with heat shields.
Old 10-13-2009, 10:06 AM
Hitman1318's Avatar
Hitman1318
Hitman1318 is offline
I wrapped the exhaust and put on the heat shield. Can feel that little bit of difference...
Old 10-13-2009, 10:16 AM
ackman1968's Avatar
ackman1968
ackman1968 is offline
It does hold in enough heat to eventually crack the pipes. It's that reason that most header manufacturers will not warranty pipes that have been wrapped. I don't think it affects the bikes like it does the headers because the stock head pipes on my bike seem to be heavier walled tubing than any of the headers I've put on my cars.
Old 10-13-2009, 12:16 PM
Mole Rat's Avatar
Mole Rat
Mole Rat is offline
I didn't feel any change
Old 10-13-2009, 02:54 PM
reesestewww
the same is good, just wont be able to deal with more heat. I sit in traffic on the way to work every day and afternoon. This FL heat is a killer!
thinking about some Xieds to richin' the mixture and maybe bring down the heat???
Old 10-13-2009, 04:27 PM
harper764's Avatar
harper764
harper764 is offline
dude, im in pensacola....i recently wrapped my pipes, and I will guarantee you will feel a good bit more heat. It's enough that I sometimes keep my right leg on the pegs at the lights. Its more than noticable
Old 10-14-2009, 05:28 PM
imeric's Avatar
imeric
imeric is offline
i wraped my buell and dyno it before and after i gained about somewhere around 10hp.I wraped my 06 springer but i didnt dyno it yet.It cracked the header on the buell were 2 pipes goes in to 1 at the weld.
To solve the heat problem try jet-hot coatings
http://www.jet-hot.com/motorcycles.html
Old 10-14-2009, 05:54 PM
sickwithit's Avatar
sickwithit
sickwithit is offline
I double wraped my pipe. It really did cut down on the heat, but my pipe also ended up cracking.
Quick Reply: The Truth about Exhaust Wrap??
