Wide Glide Rear Fender onto a Fat Bob
#181
#183
Hey guys, longtime reader, first time on forum officially! Thanks for all the info. by the way. I've ordered all parts suggested and am in the middle of the fender swap however, it seems that the wide glide fender I have is too narrow for the struts? Anyone else have this issue? I'm pretty mechanically inclinded but can't seemt to figure this out? Also the spacer seems useless?? Does it go between the fender and the strut? or on the outside of the strut cover? Any help would be appreciated. I've got a 08 Fat Bob and a wide glide fender part #60519-10, Thanks
This thread was incredibly helpful in preparation of the swap. Many thanks to all who contributed.
Here's my finished Fat Glide...
#185
#186
#187
Sorry to bring back an old thread but I just got a 2010 Fat Bob and want to do this conversion...
My question is whether or not this fender...
60519-10DH RF,DOM,FXDWG,VIVID BLACK Retail Price:$215.00
...is pure vivid black (I know it has no pinstripes, just want to make sure there weren't flames on the fender or anything).
Thanks to anyone who can help and everyone who made this post a great and insightful read!
#188
Here's a portion of someone else's post of notes on this subject. It helped me a lot during my swap. You'll need many more spacers per side than just one.
The part number you have I think is correct. The w/ps is with pinstripe.
Oh yea, don't mess with the HD rubber conduit. I just used 3m wire tie bases with 3m foam tape and ran the wiring on the sides above the nut brackets with wire ties. Cheap purchase at any big-box hardware store.
Your part number for the correct fender is on the very bottom. I mail-ordered mine from Kutter or New Castle HD, or Surdyke HD (don't remember....). Price those three for the cheapest price. All excellent service!
Hope this helps. The work is well worth the finished product!
Tim
I did the FXDWG fender switch on my Fat Bob and have seen a lot of others on the forums that have done it as well. I love the way it looks, but it's not as easy or cheap to do as you might think. Here's some things that you need to know ...
1. The fender is pretty much a bolt on swap - except you need spacers to go between the fender and strut. I used chrome washers. 3 on the front bolts and 2 on the rear
2. Paint ... You can't get the FXDF fender in any color that matches the FXDF except gloss black. So, if your bike isn't gloss black, you have new paint or powder coat in your future. I powder coated my tins.
3. If you keep the stock shocks, only the FXDWG strut covers work (and they are only available in black, not chrome). If you swap shocks, you might be able to use covers from a Super Glide or older Street Bob. I don't use strut covers but wish I could get chrome ones that fit w the stock shocks. No strut covers means the turn signal standoffs don't work - I used chrome spacers.
4. While the fender is easy, the electrical requires some work: You need to extend the turn signal wires and figure out a way to connect them to power as you lose the little circuit board at the back of the FXDF fender. This means you need to do some custom wiring.
5. You also need to figure out what to do for a brake light - I used the HD under fender LED brake light and don't feel it's enough. I'd recommend a run/stop/turn module, too. More wiring.
6. You need a license plate mount (side mount, if you use the under fender brake light) and a license plate light, if your state requires one. More wiring. You can see the cutom bracket I had made just over my exhaust. I used a Figure Machine LED plate frame and backing plate. Used a $5 waterproof switch from eBay that sticks to the underside of the strut so I can turn the plate light on and off ... its wired to plug into the battery tender connector.
7. With the new wiring that needs to connect to the old wiring connectors, I HIGHLY recommend a AMP TYCO crimper like this one on eBay. Soldering the pins is real pain and "crimping" with regular or needle nose pliers just doesn't work.
8. You need to be careful about running wires from back to front as you lose the wiring conduit that is stuck to the underside of the FXDF fender.
60519-10 Rear Fender, primed
59459-10 Left Fender Support, Black
59461-10 Right Fender Support, Black
60936-10 Inner Bracket x2
11896 Spacer x2
Anyone know if: 60519-10BJM RR,DOM,VIVID BLACK W/PS
would be a direct replacement for a vivid black FB? not sure what the "W/PS" means....
I also found: 60519-10DH RF,DOM,FXDWG,VIVID BLACK
the normal 60519-10 is primed, these (I assume) are painted...that is all I was looking for.
#189
60519-10DH.
#190
fender strut covers
gents,
gents,i am collecting the parts for this modification , now is there a seller on Ebay how has covers, its looks like the one i have to need.
he don't know the parts numbers. but what do you think, can i use those?
The are in chrome, but the will be black powder coating
eBay item 261667405653
hope someone can help me, the price is nice, here in holland the are expenser
with regards
ron
with regards
ron
