Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#5811
Has anyone here had the chance to play with a 2014 Low Rider yet? After a headlight and riser swap, I'm wondering how high you can go with the bars before you have to start extending wiring and changing cables.
#5812
I figured I would do a write up on the speed merchant radial caliper bracket install because I couldn't find anything on the net on it. I also hope you guys don't mind me putting it in here because this seems to be the thread that people would be installing it and probably looking at the most. I am a numbers guy and when I look for a tutorial or installation thread I like numbers so here is what I found to be needed to make this work on my bike. Mine is an 06 dyna with 11.8 rotors and a oem cast front wheel
I needed spacers and didn't want a bunch of washers in there to get the caliper spaced on the rotor and to get the right pad travel on the rotor. I had some 150 thousandths spacers machine from the bracket to the leg. That worked perfect for me but yours may vary. Now for the caliper to the mount my spacers were approximately 0.078 or 5/64. The inner diameter of the spacers should be about 3/8 to accommodate the 3/8 bolts. The outer diameter should be about one inch. The leg ones can be smaller outer diameter but the caliper to bracket ones need to be an inch
When I got the caliper bracket I got the one in black and as always with powder coated parts you are probably going to need to chase or clean up the threads. For the bracket to leg mounts it takes a 3/8 by 16 tap or thread chaser. For the caliper to mount it takes a 3/8 by 24. That should help you on bolt sizes too but yours may vary depending on your wheel and spacer combo. Hope this helps
ride report:
so I took the bike for a ride after I installed the new setup and it broke ok. It wasn't a huge improvement but it still felt like I had a air bubble in the line. I let it sit overnight with pressure on the brake handle and tapped it a few times. Today I rode it again (because yesterday I rode my other bike) and what a world of difference. I underestimated the change. It is hands down night and day different and better. I am thoroughly happy with it
#5820
Squid, don't worry I decided not to sell. Everyone told me I'm crazy because they would love to have my bike. I've spent years and hours upon hours to get my bike this far just to sell it? Temporary insanity.
Ive always wanted a Dyna Defender so I was looking at FXDXTs to turn into an FXDXP (since the DP's are so hard to find) but I saw a few late model Dynas with police bags and I think I can make it work. Hoping to follow 07Bobber's lead by making my bike what I want, not settling on a 10+ year old bike without some of the perks that now come stock (6-speed, EFI etc). I plan to turn this Bob into an anti-Police Dyna Defender. Hoping to be done by Christmas....
