Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#7091
Two question on T-bars
Just got some 16" and I'm 6'4".... will these be in my line of vision
also I have a FXDXT... will these clear the windshield with the gauges or can I see the gauges if I still mount them low
#7092
Have to point that most styling notes started out as attempts to improve performance in one way or another. Bobbers came from folks cutting off large amounts of sheet metal as the cheapest, easiest way to make bikes go faster and handle better; apes from guys getting older and no longer tolerating the shoulder/neck pain of lower bars, and lowered bikes from short guys dropping their too tall bikes in front of chicks they were hoping to impress....
#7093
I enjoy reading the convos posted here. Even when someone comes trying to start some ruckus, this crew maintains relative maturity.
Im going for a bit of a mix on my bike. I raised it, rather than lowering.
Im gonna try the tank lift and think it'll flow nicely if I can get the headlight/ fairing up some. Im gonna try spacers to raise the light or have my buddy machine me a different bracket, altogether. Ill have to get different brackets to mount up top. I think getting it higher will direct the wind over top of my head also.
Im hesitant as sh*t to put my forwards on cause if I don't like them thats kind of a big job.
Problem is, any ride worth talking about provokes a SH*TTY cramp in my left hip flexor.
I did get the Ness direct bolt on LED rear signals and am FUKN STOKED about that. Now Ive gotta fig out the fronts.
My buddy (Blue Suede) said he put in some cams and it made a helluva difference but I got on a cruiser to STOP the temptation of twisting the screw as much.
:endramble...
I appreciate everyones insight here. Keep it comin.
:endramble...
#7094
I can't answer the windshield question for certain but at 6'4" the 16" will not be in your line of vision. the windshield angle is adjustable I believe so your probably good on that front too but I can't speak from experience.
#7095
It's gonna depend on how high you mount the gauges. If you get em up high enough to clear the center bar, you can see em just fine. I had mine mounted low for a while...you can still see em but visibility is limited. Unless you go completely above the windshield, you will have to adjust it forward just a hair to clear the gauges. You'll also need an extension for the tach cable that runs back up under the seat. Can't comment on the line of vision with the bars as I'm only 5'11" with 12s
#7097
Better to know for sure before spending a lot of money.
#7098
I'm 6'3" and have 14" T-bars...
They are well below my line of sight.
I considered 16's, but I'm happy that I stayed with the 14's.
#7100
:endramble...
:endramble...
