Sundowner Seat on Street Bob
I recently purchased a sundowner seat for my Street Bob and I noticed that the seat has a metal bracket that screws to the rear fender. I am wondering whether the metal bracket will scratch the paint of the rear fender?
Do you have any experience with this? I went to talk to the people at the dealer and they said that there isnt anything for it. They suggested the seat bumper kit which I already have.
Harlista01
Harlista01
My metal bracket looks aweful close to the paint but instead snugs up the the nylon c-clip that holds the seat hardware to the fender.
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
There should be a silver-dollar size contour "washer" that fits up thru the fender from underneath. It has an internally threaded post about 5/16" high that sticks up thru the top surface of the fender and has a locating tab that keys it to a matching notch in the front [of bike] side of the hole in the fender. A matching washer goes over the post/tab so that the fender is sandwiched between these two silver-dollar size washers. Your seat tab should align with the washer's post/hole, and a socket head cap screw secures the seat tab to the washer/fender sandwich. I have the front mounting tab of my fender rack that fits on top of the seat tab on my setup. So your seat tab only contacts the topside washer; nothing to scuff paint. Look closely and you can see the large topside washer in this picture...
1 Post
I don't have any additional data or part numbers for you; the setup was already on the bike when I bought it. I can tell you that both pieces are chrome, both are contoured to fit the curve of the fender, and the top one is polished up pretty well so it presents a smooth contact surface to the paint of the fender. I've had my seat(s) off a dozen or more times for swaps & cleaning, and I've never noticed any witness marks left by the washer in the paint.
One other thing comes to mind; I'm pretty sure that the threaded post of the underside washer protrudes above the top surface of the topside washer by about the thickness of the seat tab. The diameter of the post matches the hole size of the seat tab. The resulting stack ends up with the top of the post being pretty much flush with the top surface of the seat tab.
