Shift Pattern for 06 Dynas with 6 speed
Old 07-05-2006, 01:22 PM
rap87's Avatar
rap87
rap87 is offline
Default Shift Pattern for 06 Dynas with 6 speed
I was curious to see where you guys shift at for normal everyday driving and what speed you cruise at in what gears. I don't have a tach, and I am used to a 5 speed trans...and sometimes it seems it sounds like it wants to shift sooner than I'm used to. Like in 4th gear going a50 miles an hr it sounds like it wants to shift to 5th, but I wasn't sure if that would be lugging the engine going 48-50 in 5th. Also going 60 in 5th gear it sounds like it wants to shift to 6th...same deal as the 4th to 5th shift. I saw a post in general where a guy did a dyna trans break down. I can use that to figure this out if someone knows the sweet spot RPM is? Thanks.
Old 07-05-2006, 01:35 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
Default RE: Shift Pattern for 06 Dynas with 6 speed
ORIGINAL: rap87
Like in 4th gear going a 50 miles an hr it sounds like it wants to shift to 5th...Also going 60 in 5th gear it sounds like it wants to shift to 6th...
Dunno if its lugging it or not, but that is more or less how I do my shifting (20/2nd, 30/3rd, 40/4th, 50/5th & 60/6th)...
Old 07-05-2006, 01:49 PM
rap87's Avatar
rap87
rap87 is offline
Thats what I think the book says as well, but in 5th gear if you dip down to 47 mph is that considered lugging it. Its pretty common to have to drop down a few miles in traffic like from 52 to 47...making sure my ears are still hitting the sweet spot...
Old 07-05-2006, 02:47 PM
PowerCobra98's Avatar
PowerCobra98
PowerCobra98 is offline
I've put a tach on my bike and basically look at it most of the time. For shifting I shift into 3rd at 30, 4th at 40, 5th at 50, and 6th at 60. For every one of those shifts the bike goes to about 2200rpm right after the shift. For the "normal" riding the rpm shift point is around 2800rpm.
As per your question for 5th gear and shifting. I shift to 5th at 50mph and if I stay above 50 it's all good but if you slow down to below 50, say like 47mph, then the rpm drops to around 1900-2000rpm and it's starts to lug so I downshift to 4th. Hard part is that most cagers like to sit in that "no-man's land" area of mph and if you're behind them you find yourself up and down shifting constantly.
superdog48's Avatar
superdog48
superdog48 is offline
HD_SOB thats the way I usually shift mine. If I'm rididng at 45 MPH I'll stay in 4TH gear.
Old 07-05-2006, 03:26 PM
rap87's Avatar
rap87
rap87 is offline
So, I've probally been doing it right. 4th gear at 50 mph, 5th gear at 55 mph, 6th gear 65mph all cruising...
Old 07-05-2006, 03:37 PM
TRITON's Avatar
TRITON
TRITON is offline
Your RPM Ears are fine I shift the same way, but usually wait till about 65 or over before hitting 6th. I have noticed that my bike does not like to go between 45 and 50. At that speed there just isnt a good gear.
Old 07-05-2006, 04:16 PM
Pixs's Avatar
Pixs
Pixs is offline
ORIGINAL: PowerCobra98
Ditio!
Forty to fifty is a killer zone; in traffic 3rd gear, on the road, 4 th gear. I'll use 6 th gear to cruise at 55 but if you need to accelerate yaha gotta shift to 4th or 3rd.
Old 07-05-2006, 04:30 PM
johnpiech's Avatar
johnpiech
johnpiech is offline
I don't use 6th at all. I'm surprised that they did not gear it down a little bit. A couple teeth more on the rear pulley seems to be in order. 5th is good to over 100, which is about as fast as I want to go before the thing wobbles just a little. Between 70 and 90, 5th is just fine.
Old 07-05-2006, 04:53 PM
rap87's Avatar
rap87
rap87 is offline
I'm sure its fine, but its burning up way more gas than it needs to. I want to know the best way to save gas in gears w/o luggin it.
Quick Reply: Shift Pattern for 06 Dynas with 6 speed
