need torque spec for swing arm axle 07 dyna
12-19-2009, 07:15 AM
Need the torque spec for the swing arm axle bolt for an 07 Dyna
Thanks
12-19-2009, 08:10 AM
Rear Axle Nut - 60-65 ft/lbs
Swingarm Pivot Shaft Nut - 71-75 ft/lbs
12-19-2009, 09:10 AM
The '07 manual says 92-98 ft-lb for the axle nut. If I remember correctly, my '03 was 60-65. '07 is different.
12-19-2009, 11:38 AM
I used the 06 manual and assumed they would be the same. Thanks for the correct info.
12-19-2009, 12:17 PM
Good luck getting a torque wrench on it, unless you have the inner primary removed.
12-19-2009, 12:24 PM
Swingarm pivot shaft is 71-75 ft-lbs. And the rear axle is 92-98 ft-lbs.
12-19-2009, 10:40 PM
why would the axle nut torque value increase by 50% from 06to 07??????????????
wing-nut50
04-10-2022 04:24 PM
djdiver157
Wheels/Tires
06-01-2017 12:13 AM
clap
02-21-2015 07:01 PM
cpsychoholic
09-08-2010 07:17 PM
robertj74
04-10-2008 05:05 PM
2005 ,
2007 ,
arms ,
axle ,
dyna ,
dynas ,
glide ,
nut ,
primary ,
rear ,
spec ,
specs ,
super ,
swing ,
swingarm ,
torque ,
wide
