DYNA Oil Coolers
#31
Is this the same kit you have?
I found a discontinued Harley Davidson oil cooler that is made by Jagg on eBay. More info in the below link
https://www.hdforums.com/forum/dyna-...il-cooler.html
#32
I went with new cooler from H-D. My installation here:
https://www.hdforums.com/forum/dyna-...installed.html
#34
#36
I have the Jagg slimline 1200 mounted on the left frame tube.
I just modified to fit AN6 with 1/8" pipe into the cooler.
Cut the tubes and tapped 1/8 pipe, the cooler adapter already has 1/8 pipe just screwed in the AN6 to pipe adapters.
I had a hose pop off and made a mess and almost dropped the bike through the curves.
A bit costly but worth the peace of mind.
insted of the straight hose connection I have flared fittings and Stainless braided hose. Purchased from jagg.
Amsoil passed the test of no oil in the engine!
Drained for 2 days, nothing on my magnetic plugs!
Having the AN6 flare fittings gives me the option to completely drain the cooler at oil change time. Undo both hoses to properly drain. Nice option.
#37
#38
From another thread:
I used Loc-Tite on the "treads", and haven't had a connection issue since:
https://www.hdforums.com/forum/dyna-...n-battery.html
Also my oil cooler hasn't been taken out by road debris yet, my drilled handlebars haven't cracked yet, thread sealant on my oil drain plug hasn't clog my oil passages, the edges of my chopped air filter cover hasn't rusted yet...........The what ifs never happened.
#39
