Fat Bob Front Brakes Question
Fat Bob owners do me a favor and tell me if this is normal... I have a 2010 recently purchased with less than 500 miles - last weekend I wanted to get comfortable with the bike so in a school parking lot was practicing emergency stops to get a feel for the brakes... Noticed that every few stops brakes would chatter just a little versus come to a smooth stop - and even just rolling back and forth in garage when I apply front brake the pad slaps or "clunk" as it come to an abrupt stop.
Can someone tell me if their front brakes do same and if I should take to get check at dealer - or am I worrying about nothing???
take it to HD and have them adjust the fall away etc on the front neck-document every time you take it in save all your receipts. That problem is supposedly fixed on the new models, but I started taking in mine at 4000 miles until 46000 when they finally gave up and said it needed a front end rebuild-they wanted 400 to fix an item I had been bringing them for 2+ yrs. I spent $24 on neck bearings and it fixed it.
You probly just need to get it adjusted but don't let any of them tell you 'oh they all do that' cause they don't and shouldn't.
brake discs are semi floating, I would think that when they heat up, the metal expands tightening the tolerances and it goes away? could just be the tolerance built into the disc. Of course could be front end clunk too. Also if the chatter happens now and again, your brakes could be less than worn in with so few miles.
Yeah a loose front fork can easily be mistaken for pad noise. If I recall several months ago someone here was reporting a similar problem when coming to a stop and a fork adjustment fixed it. There was also reports of clatter but it turned out the motor mounts were not aligned properly and the engine was moving so far forward it was taking up all the sway space... .
