Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 07-22-2006, 04:14 AM
clayman clayman is offline
Default Help using the SERT
I just got my sert and was given some help from a member but i am a bit stumped and could use a little direction on how to get started and do this, i am a little intimidated by this type of stuff. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 07-22-2006, 08:55 AM
PowerCobra98's Avatar
PowerCobra98 PowerCobra98 is offline
Default RE: Help using the SERT
First, install the software on your laptop.
Second, fire up the software program and open up the calibration map you want to load.
Third, locate the data uplink port in the fuse box.
Fourth, connect the data cables to the laptop and the bike.
Fifth, turn the ignition and run switch on but do not start the bike.
Sixth, go the File and Program ECM.
Seventh, Push the Get ECM Info button to ensure the laptop and ECM are talking to each other.
Eighth, Push the Program ECM Cal button and let the map load into the ECM.
All of that is spelled out in the SERT manual, just take the time to read it and you'll be fine. If you have COM port issues just follow the directions in the manual to sort them out.
Good luck.
__________________
- Scott - <><
2006 Dyna Super Glide Custom - FXDCI
!@#$&^*% where's the freakin' horn on this thing??
Old 07-22-2006, 09:25 AM
2005UltraNC's Avatar
2005UltraNC 2005UltraNC is offline
Would suggest you "play" with the Data Mode first. This allows you to see that the SERT is talking fine with the ECM and can see how it collects data, etc. Would do this before installing any new hardware (pipe's, AC). Collect data and store it, gives you a baseline.
When in the Tuning Mode, be sure to hit the "Get ECM Information" button before programing (makes sure the SERT is talking to the ECM). Would also recommend to name the file (Map) with the date you've downloaded (for Example, "Map downloaded July 21 2006") - this way you can look in the folder on your laptop and see the different filenames / maps that you've downloaded.
Also, keep in mind that once you download a map, there's no way of going back to the orginal Stock map (dealer would have to reprogram).
__________________
95"Big Bore,HD Flat Top Pistons, Andrews TW-26G ,
SERT, Feuling Super Oil Pump, Feuling Lifters
HD Adjustable Pushrods, Big Boyz Ported 9.5, FAT CAT 2in1
Old 07-22-2006, 10:00 AM
jaysonL's Avatar
jaysonL jaysonL is online now
Can I be nosy and ask how much a SERT co$ts ?
__________________
http://i39.photobucket.com/albums/e178/jayleav/100_0333.jpg
Thunderheader , Thundermax auto tune , stage I a/c , and various shiny things .
Old 07-22-2006, 10:15 AM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
Quote:
ORIGINAL: clayman
Congratulations clay. You're gonna be happy with the race tuner.
Cobra and ultra lay it out there real nice.
Software comes with a bunch of maps. You can pick one close to your setup.
I didn't go that route, another member emailed a few maps.
tryed one, night and day from the dealer download.
The next one was a fine tune up from the first.
I believe my motor is very similar to your configuration.
Mine runs like a cat with it's tail on fire now,
and it is very smooth throughout the entire rpm range.
Really amazing how easy it is to reconfigure with the race tuner.
mud
__________________
Old 07-22-2006, 11:26 AM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
Quote:
ORIGINAL: jaysonL
390 at my dealer after my senior discount.
I didn't shop around. Didn't know about Zanotti then,
probably cheaper there, and maybe other sources as well.
Check around jayson. Post back what you find.
07dynaMud
__________________
Old 07-22-2006, 12:18 PM
springer_'s Avatar
springer_ springer_ is offline
This will get you started. It is a slightly older version but basically the same. http://www.hdforums.com/m_222256/tm.htm
Old 07-22-2006, 01:46 PM
JamieWG JamieWG is offline
Once you figure out how to upload a map to your bike, send me a PM and I'll send you a good map for '06 Dynas.
Old 07-22-2006, 04:36 PM
Quote:
ORIGINAL: JamieWG
Already sent him a nice one! Our maps are pretty darn close though.
__________________
- Scott - <><
Old 07-22-2006, 09:35 PM
ive downloaded it twice now and it is still running the same as before. Not sure if im missing something but it says that its been downloaded. i am getting frustrated with this and am about to put the old exhaust back on.
Tags
harley, sert
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
