***Dyna Models Wiring Diagram Links Index*** part 1
Old 12-20-2012, 09:29 AM
AxelF's Avatar
AxelF
AxelF is offline
6th Gear
Here's the wiring diagram for the 2010 FXDWG with center stop lamp...
Go here on some info on how to open the AMP multi lock connectors:
Sorry, between these two lines your diagramm is missing......
i canīt see it
So if you can email me the plan it would be great.
Thank you and mery christmas...
  #82
Old 12-20-2012, 10:26 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Axel,
Her's the link to the image:
https://www.hdforums.com/forum/attac...1&d=1356262947
I think you need to make some changes in your settings.
Go to your User CP (click in blue bar)
Click Edit Options
Scroll down until you see Thread Display Options
Now put a marker in the checkboxws at Visible Post Elements
Scroll all the way down and click Save Changes
Go to your thread and check if you see the image now.
Let me know if this woks for you or not....
  #83
Old 12-22-2012, 05:29 AM
AxelF's Avatar
AxelF
AxelF is offline
6th Gear
Default The plan is missing
Hey
i already had a klick at the options you described.
I can see your link now, but if i follow, i receive this information from the HD Forum:
vBulletin Message
Invalid Attachment specified. If you followed a valid link, please notify the administrator
Sorry for these problems while you are trying to help me....
Greeting
Axel
  #84
Old 12-22-2012, 08:40 AM
FXD2003Rider
Originally Posted by AxelF
Hey
vBulletin Message
Greeting
Axel
Email sent.
  #85
Old 12-23-2012, 04:53 AM
AxelF's Avatar
AxelF
AxelF is offline
6th Gear
Default Got it
Thank you so much for your patience and help but this is the plan of the Dyna Model 2012.
I do need the plan for the model year 2010...
So sorry...
Greetings
Axel
  #86
Old 12-23-2012, 05:45 AM
FXD2003Rider
So sorry...
Greetings
Axel
Drawing the wiring diagram I made a typing error....
Changed it into 2010.
  #87
Old 12-23-2012, 06:40 AM
AxelF's Avatar
AxelF
AxelF is offline
6th Gear
Thank you.........
  #88
Old 01-10-2013, 08:14 AM
FXD2003Rider
Default Harley-Davidson's B+ connector
Some H-D models have a B+ (hot wired) connector to connect accessories.
This Delphi MP 480 series (unsealed) connector is situated under the seat.
Image below shows some detailed info on this connector & the H-D ACCESSORY ADAPTER HARNESS KIT 70270-04 (link to instruction sheet):
  #89
Old 04-01-2013, 02:00 AM
AxelF's Avatar
AxelF
AxelF is offline
6th Gear
Default Finished....
Good morning and happy easters,
here is a photo of the result
Thank you very much for your help.
Greetings
Axel
Attached Thumbnails ***Dyna Models Wiring Diagram Links Index*** part 1-img_1162.jpg
  #90
Old 05-24-2013, 10:17 PM
gummi's Avatar
gummi
gummi is offline
Stage I
Default Dyna Wide Glide 2011 Wiring diagram
Hi,
Does anyone know where to find a wiring diagram for a Dyna WG 2011?
My model doesnīt have a tail lamp, itīs built into the turn signals.
Iīm going to install a new tail lamp and nead to sort out the wiring to the tail lamp. At the moment there are only 3 wires to the turn signals.
Black - Ground
Blue - Constant running light?
Purple/brown (or similar) - Which seems to be both turn signal and brake signal in the same wire.
I also need to know wiring to the front turn signals, Iīm going to disconnect the constant running light and need to find out where to cut those wires.
All help is much appreciated!
/Martin
Quick Reply: ***Dyna Models Wiring Diagram Links Index*** part 1
