Battery Tender permanent install question
Tomt I think I might know where you got the idea for your setup....
For the OP, it's going to be tight but if you take your time there is enough room for the charging pigtail. Running it across the bike and behind the electrical panel is a good solution for hiding the plug but keeping it accessible. That electrical panel cover just pops right off.
Must be different on older models, mine has the terminals on the inside so you get to them under the seat.
The previous owner had the dealer install the pigtail, they have it ziptied to the bracket for the passenger peg on the battery side of the bike.
Easy to get to, just plug it in works great.
See below for an inexpensive easy quick connect / disconnect Battery Tender hook up. Mines out of sight, mounted and recessed under the coil cover.
Run wires directly to the battery (use Loc-Tite). To make a quick connect / disconnect you can solder wires to a banana jack and mount it some where out of sight. Use an additional banana jack on the Battery Tender leads. http://shop3.frys.com/product/237909...H:MAIN_RSLT_PG
Yes I do, a little tricky tightening the nuts, but no big deal. Will take a pic for you tomorrow, no lighting out in the garage. Since it is all black, it is hardly noticeable.
https://www.hdforums.com/forum/dyna-...-question.html
When I got the heated jacket. I didn't want to keep plugging it into the pigtail that came from the battery for the tender. It was hanging under my seat on the frame. I found powerlet product.com after a long search on Google and purchased the Luggage Electrix Connector.
Let me know who has this setup. Is it you? If so, sorry to say, you were not the influence for my idea. It would have saved me a lot time searching on Google for a connector.
