2005 Dyna Battery Box
Old 02-22-2010, 07:13 PM
firestop52's Avatar
firestop52
firestop52 is offline
Default 2005 Dyna Battery Box
I have a friends 2005 Super Glide in my garage for the winter. I was going to charge the battery for him but I can't figure out how to remove the cover. It looks like the top will slide out but I am not sure and don't want to break anything. I hate to ask such a simple question but I thought I would ask first this time rather then tear something up and have to replace it before I know how it works. Thanks for any help.
Old 02-22-2010, 07:19 PM
BeanDyna08's Avatar
BeanDyna08
BeanDyna08 is offline
Default battery box
Not sure if they are the same but I have an 08 SG and on the bottom of the battery cover there is a screw that comes out. The bottom swings out to unhook the top.
Old 02-22-2010, 07:31 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,281 Likes on 2,349 Posts
1. Remove the seat. 2. Looking at the box, immediately to the left is a bolt that screws into the frame, remove that bolt. #. Above the bolt is a bolt that screws up, as you are loosening that bolt the box may have to be "thumped" by your hand to loosen it, as the bolt comes out the battery box should drop down. Install is reversed. The battery top cover goes on before the box is moved up.
Old 02-22-2010, 07:55 PM
firestop52's Avatar
firestop52
Thanks a lot for the help, there are quite a few differences between 2005 and 2006.
05DynaGlide
08-08-2014 11:25 AM
angellobo3
03-02-2011 07:31 AM
NOPOINTS
11-12-2007 09:13 AM
fitzster
04-14-2007 09:36 PM
kenn101
04-05-2006 03:10 AM
Quick Reply: 2005 Dyna Battery Box
