Fat Bob mini power-wheelie
Old 03-03-2010, 09:54 PM
Centerline's Avatar
Centerline
Centerline is offline
Default Fat Bob mini power-wheelie
Finally had some time to get a video of the bike an it's mini first gear power wheelie. It didn't do these with just the 103" upgrade... but it's character changed entirely when the stock sprockets were changed.
Original front sprocket: 30 tooth, replaced with 32 tooth
Original rear sprocket: 66 tooth, replaced with 70 tooth.
It is now geared much lower than stock, too low as in 6th gear at 70 mph it is turning 3,000 RPM where it used to be I think about 3,000 RPM at 80 mph.
Anywho, all that is necessary in first gear at about 5-10 mph is just whack the throttle open, no clutch action, and up comes the front wheel a few inches....
Click in photo, takes you to photobucket
Old 03-03-2010, 10:11 PM
mikel61101's Avatar
mikel61101
mikel61101 is offline
I'm to big a sissy to try it on my scoot... but I love it....
Old 03-03-2010, 10:15 PM
blacknsilver's Avatar
blacknsilver
blacknsilver is offline
+1 But it's Cool !
Old 03-03-2010, 10:32 PM
Just Enough's Avatar
Just Enough
Just Enough is offline
That's really pretty cool, now all you have to do is kick it into second on the way up to keep it going.
Old 03-03-2010, 10:37 PM
Jutdees's Avatar
Jutdees
Jutdees is offline
thats 100% awesome.
Old 03-03-2010, 10:45 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
lol that's awesome, Centerline.
Old 03-03-2010, 10:50 PM
ElusiveThorn's Avatar
ElusiveThorn
ElusiveThorn is offline
That made my night. I love that ****
Old 03-03-2010, 11:42 PM
JaronB's Avatar
JaronB
JaronB is offline
That's awesome and sounds good too!
Old 03-04-2010, 07:24 AM
spence's Avatar
spence
spence is offline
I did the evo 30 tooth and woods cams and it will pull the front easy'
I have s&s 106 kit waiting on heads and then it should rip.
spence
Old 03-04-2010, 07:57 AM
8541hog's Avatar
8541hog
8541hog is offline
Just curious....
You sure about your tooth counts?
According to your numbers you only changed from a final drive of 2.976 to 2.960 adding teeth to both would negate any real gains in gear ratio.
You can check gear ratio changes here:
http://www.bigboyzcycles.com/Gearratio.htm
Quick Reply: Fat Bob mini power-wheelie
