Looking at buying a 2000 Wide Glide... Opinions
#31
I know I'm late to the party on this one, but be aware of the not uncommon rear cam bearing failure on 99-00 TC88s. I know first hand about this fault, which really should have been a factory recall but the MoCo got away with it because it's not a 'safety' issue.
My 00 FXDWG had 10400 miles it when the rear cam bearing went...causing over $2000 worth of engine damage. Thank God I was close to home! The only way to prevent this semi-catastrophic failure is to change the rear cam bearings to the newer type as specified in the 'official' Harley fix or do what I did and convert to gear-driven cams.
I can't believe the MoCo wouldn't even cover the parts for this fix because my 00 was out of warranty. (They extended warranty coverage on this issue to 5yrs/50K miles). My bike was 7yrs old but only 10400 miles on it...out of luck. Total crap.
That said, I know have a pretty much totally rebuilt 95" stage 2 with gear driven cams and it goes like stink...$3200 later...(gear drive and some other stuff pushed the total cost way up). Good luck with your purchase.
Maybe the work has already been done on this one? Can't hurt to ask.
#32
#33
Iasues
Looking at buying a 2000 Dyna Wide Glide. 6200 miles, one owner. Said to have Factory stage 3 kit. What does this entail? Also, its fuel injected.
Are there any issues/problems with this year bike? Seems to be not used much, ridden a few times a year, and said the bike is spotless. Price is asking $9500 on it. Looking for some input
#34
If you think about it, someone spent the money on upgrading the motor and then only averaged 620 miles a year? That would make me wonder how it actually rode and if reliability comes into play. With not knowing when the motor was done, I would be a little cautious, and $9500 in my opinion is way too much.
#35
2000 fxdwg was my first harley love my bike I've heard the timing chain tensioner were plastic. So to replace to had to pull the motor because there is one inside one outside of casing . Most people take advantage of upgrading those tensioner which also relocates the oil pump. Other than this issue I have not had an issue w my ride just about to role over 30k 6k last summer
Also, judging from your post, you might keep your technical advice to a minimum ... no offense intended
Welcome to the Forum
The following 2 users liked this post by multihdrdr:
Campy Roadie (12-30-2020),
Dudepants (12-30-2020)
