Forward controls on, rear brakes barely work, no brake lights
I have a major problem that I need help with, I put new forward controls on my 03 superglide, they are from hd and the right parts.. I did one side and my brother did the brake side..I found out instead of pulling the pin at the foot control.. he backed the fitting attached to the brake rod all the way off.. I am assuming not good!!!.. Anyhow.. we got everything on the brake side hooked up.. went for a test drive and very little brake at all.. Have to press way to hard to get anything at all and when the pedal is pressed no light on brake light at all.. running is ok.. but no brake.. can anyone help.. please.. I have tried to adjust and no success... Thanks all
I checked the wires they are ok, didnt change master cylinder, just the controls.. the pedal is hard as a rock no movement barely..Im going to bleed the brakes today and pray, thank you everyone
When the push rod was put into the master cylinder, how far was it screwed in? Look very closely at the rubber boot. Disconnect the pin at the brake pedal, then see how much travel you have in the cylinder when it's not connected. It's possible that it's not threaded in far enough. And if it's not moving properly when connected you have a linkage problem of some sort.
To disconnect the brake rod in the way you described, he had to turn the cylinder itself-not kosher but not necessarily a problem. It shouldn't have created the kind of situation you described-with a hard pedal (which generally means the brakes don't need bleeding unless the cylinder's bottoming out, BTW) - I'm wondering if he didn't adjust it too tight or in any case the brake pedal or rod is interfering with the frame, exhaust, etc?
I really appreciate it.. and this website.. I am slowly learning alot from this and everyone here.. I hope to be able to contribute my knowledge gain someday..... Well my lady is PMSing so Im outta here for a little while,, goin riding.. Thanks again...
