Brake Light Switch ughhhh
I broke the little tab off of mine a few years back and ripped the boot. I used some RTV and a tack head about an 1/8" in diameter and stuck it on the end of the button where the tab broke off. Let it cure for a day and worked awesome for a very long time, when I did a bar swap many moons later I finally did the switch change.
I know I had my master cylinder apart more than once on my old Dyna and the switch was never an issue for me. Now that I've said that, I'm sure to destroy the one on my new bike.
No big deal, it's easy enough and you'll figure it out.
If your careful and aware of the switch it's not a big deal,
,IF, , it get's damaged it's during re-assembly when the lever/master cylinder section is mated to the switch control section and the lever is jammed against the switch,, trouble happens when the rubber covering the switch is torn.
Take it all apart and install your new lever first,, then pull the lever back and stuff a folded over chunk of cardboard between the lever and master cylinder,, holding the lever back.(fold it 3-4 times)(cut a slot so it fit's around the rod/cable) That keeps the inside part of the lever away from the switch.
It's easier to mount the grips and controls on the new handle bars before the handle bars are installed in the riser,, you have more movement.
I must live a charmed life...I have had the controls on my SG and son's WG apart at least two dozen times and I have never used this method and have never broken a switch. I carefully take it apart and carefully put it back together...
My son took his apart only one time and broke the switch. (We didn't get the $60 MoCo part, we got the $15 aftermarket replacement switch for his ride...and a spare to have on hand just because I respect Murphy's Law.)
