What Size Star Bit?
Old 04-19-2010, 02:16 PM
Stixman's Avatar
Stixman
Stixman is offline
Default What Size Star Bit?
I have a 2006 SuperGlide FXDI.
Can anyone tell me what size star bit fits the fender strut bolt?
Thanks.
Old 04-19-2010, 02:19 PM
Slopneck's Avatar
Slopneck
Slopneck is offline
Well, first of all make sure you have the Torx Plus bits and not the regular Torx! (Learned the hard way one stripped fender strut bolt later...) I wanna say those bolts are 27 but I could be wrong. If you get the Torx Plus set it will be in there. They are just a bit harder to find.
Old 04-19-2010, 03:36 PM
Nickpisp's Avatar
Nickpisp
Nickpisp is offline
I'm thinking 40 or 45...
Old 04-19-2010, 04:49 PM
AFblacksheep's Avatar
AFblacksheep
AFblacksheep is offline
Its a T40 I just removed it this weekend.
Old 04-19-2010, 05:06 PM
jaysonL's Avatar
jaysonL
jaysonL is offline
I have the torx set from Stanley . they have worked very well , way beyond my expectations . And , I never heard of Torx plus . But , yeah , it's a T40 .
Old 04-19-2010, 05:11 PM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
So how do you know if they're Torx or Torx Plus? Does the service manual identify which are used where?
Thanks
Old 04-19-2010, 06:17 PM
ecvjohnny's Avatar
ecvjohnny
ecvjohnny is offline
the torx screws suck ***! i'm slowly getting around to changing all mine to allen heads.
Old 04-19-2010, 11:16 PM
Stixman's Avatar
Stixman
Stixman is offline
Thanks everyone. It is indeed a T40.
The right side bolt came out easily enough using a little muscle.
The left side, not so much. Stripped
Time to call in someone more talented than me.
Old 04-19-2010, 11:17 PM
Stixman's Avatar
Stixman
Stixman is offline
agreed!
Old 04-20-2010, 09:40 AM
Slopneck's Avatar
Slopneck
Slopneck is offline
Here is a link. http://www.wihatools.com/700seri/716serie.htm
The MoCo uses Torx Plus bolts, not regular Torx. Each one is slightly bigger than their regular Torx counterpart. So if the bolt is not in there REALLY tight, often times a regular Torx bit will work. But what I found is that when I bought my bike new it was like they put the freakin things in with an impact wrench, thus my stripped bolt. Then I ended up having to take it into the dealer to get it removed. Hmmmmmm......you don't think that's what they had in mind when they decided to use the Torx Plus do you???? Nah....I'm sure that's not it!!
Quick Reply: What Size Star Bit?
