Dunlop D404 or D402? What's the difference
Old 04-25-2010, 08:20 PM
FotoDeville's Avatar
FotoDeville
FotoDeville is offline
Default Dunlop D404 or D402? What's the difference
I'm thinking about new tires for the Dyna. Harley sells the Dunlop D402 with their name on the sidewall. I can find the D404 online for a lot less money. Do you have any advise? Are they the same tire with the exception og the sidewall name?
Old 04-25-2010, 08:39 PM
dope_man_21's Avatar
dope_man_21
dope_man_21 is offline
http://www.dunlopmotorcycle.com/tire..._tire.asp?id=5
The D402 is the approved Harley-Davidson touring tire.
Built with a three-ply polyester casing with two fiberglass belts, the D402 offers greater load-carrying capacity and stability.
D402 front is a 72H (783 pounds and 130 mph)
D404 front is a 57H (507 pounds and 130 mph)
D402 rear is a 78H (937 pounds and 130 mph)
D404 rear is a 74H (827 pounds and 130 mph)
The D402 is a stiffer side wall to accommodate the heavier bikes.
Old 04-25-2010, 08:44 PM
dope_man_21
I have ran the D404 and the front tire was my problem, the tire just was not stiff enough, the rear tire seemed fine. I ended up going with a Pirelli Night dragon 180/60HB17 9but that was just 10mm wider than my stock tire.
Falcon195
04-06-2015 05:48 PM
Falcon195
10-08-2013 11:32 AM
Altorr
01-16-2010 10:32 PM
trackadaptor
11-08-2009 08:26 PM
policepop
Wheels/Tires
05-18-2009 09:02 AM
Quick Reply: Dunlop D404 or D402? What's the difference
