Scavenger Oil Change on a Street Bob
So, I broke down and bought a Scavenger oil change kit from Rouge Choppers. I went out to change my oil on my 2007 Dyna Street Bob.
#1 - If you have V&H Short Shot's you will be running into problems like me. You have to remove the rear pipe to gain access to the oil filler cap and allen bolt. Yeah...didn't know that one.
#2 - It's a bit more messy than they lead on. Once you take the puck off, it's still filled with oil...so be prepared for that. The clear tube, yeah good luck on getting that clean.
#3 - Changing the oil on the jiffy stand, I'd recommend that you get some sort of jack or stand to keep the bike level.
I like the kit none the less. I feel that the bikes oil is definitely cleaner than it would have been if I hadn't flushed it. The oil coming out of the clear tube was pretty bad. That's what would be hitting your brand new oil filter...so ya.
Money well spent...sure. I mean I'll be using it everytime. I've already had some friends ask me to change their oil. I'm charging them $10 above cost. So, if I do a couple bikes...it'll pay for itself.
Just wanted to give everyone a heads up about some of the things I ran into.
I found a video from rogue. It looks like a pretty good idea?
http://www.roguechopper.com/video-dyna.html
I just used mine for the first time last weekend and it was nasty what came out of the motor. Went for a 10-15 mile ride after and I couldn't see the oil on the dipstick, had to look for the reflection.
I got the same one from Rouge Choppers.
@ Bucket........... Watch the video that mike posted and what it's suppose to do is get rid of all of the old oil so when you put the fresh oil in it does mix with the left over old oil. From talking to people with our air cooled motors that run as hot as they do it's a good thing.
I like it and will be doing it every change.
Cost is a bit steep $120.00, but I'm glad I bought it. I don't have to remove my exhaust. I don't know what you have for exhaust, but the straight shots both pipes come across the front of the filler neck. If you watch the video below you can try and see if make it work without removing the filler neck. I don't know if the angles will allow it with the metal piece you put in the return line. Plus when you remove the filler and put in the adapter it uses the filler neck bolt to hold it in place so you don't have too.
http://www.roguechopper.com/products..._Kit_RC160.htm
@nkauf21 - I'm at lakenheath as well
The easy way to see if the adapter will clear the side shots is to take a regular allen key and try to remove the filler neck. If you can remove the filler neck with the allen key, then you are probably golden. I burnt my hands about 10 times trying to take the filler neck and then the pipe off. The exhaust gasket is cheap, but that's not the point. I just wanted people to understand some of the problems that are out there.
@JaronB - I have the electronic dipstick. Made checking my oil very easy. Without it, I would have had to lay the dipstick on a paper towel to check the level. The oil was very clean.
