Big spark plug problem!!!
get a manual for starters. You could bring that cylinder to top dead center so that both valves are closed then run a spark plug tap into hole to clean out. Then using compressed air from a chuck blow into hole so that all debris exits out of the plug hole. This is risky but would save you pulling your head depending on your mechanical experiance. I have used this method on vehicles. The only differencde would be is that the vehicle plug holes were not vertical like the trucks i worked on. Its up to you good luck
http://www.popularmechanics.com/cars...repair/4212608
I've seen guys actually use a Shop Vac to get any little chips or metal out of the hole.
I run away when they do that. Gas fumes and electricity scares me.
CB
I would not use a heli-coil, you need to use an insert that is staked. http://www.timesert.com/html/sparkplug.html
If you chase it with a tap, grease up the hole and the tap to catch the shavings, again you need to make sure you are going to engage the "good" theads or you will just screw them up. Believe it or not It does take some skill to properly repair the threads and with out seeing the damage it is hard to recommend what is the best approach.
CB
I would try this first.
http://www.sears.com/shc/s/p_10153_1...0070921x00003j
CB
A pisser, to be sure. But not the end of the world. The threads can usually be repaired or a helicoil inserted by a competent wrench.
A Tip: If, in the future, someone doesn't trust their spark plugs to come out cleanly (as in, not bring the threads in the head with them), loosen the plugs by about a 1/8 turn while the motor is warm to the touch. Not hot, not cold -- Warm and no more. An OBTW, make sure the plug well is clean of dirt and debris first.
Then fill the well up to the bottom of the jamb nut on the plug with something like Blaster and let it sit for at least fifteen minutes. It will wick down the threads (and probably into the combustion chamber) and help break them loose. Work the plugs back and forth a little bit as you remove them if you feel the need -- Gently. Don't over-do it, you can cause more damage this way.
As far as getting the Blaster or solvent out? That's your call. If you're **** (like me) -- Well, use your own judgement.
CB
CB
I agree.Don't force it and make sure the tap goes in straight. As a secondary precaution I would turn the motorto TDC on the compression stroke, as previously recommended. Then you can either blow any remaining shavings out or vacuum them out.
