SE 255 cam in my 07 dyna
I just did mine and I replaced all the o-rings in the camchest (3), o-rings on the pushrod covers.
Cam cover gasket, 2 rocker box gaskets, 2 breathers/breather gaskets, o-ring in the rocker box.
I reused my stock pushrods and bearings. If I had easy access to a puller/installer I would have swapped them.
You will want to inspect your two cam chain tensioners. You may or may not have to replace them.
My bike had the .110 spacer and I had to use a .130 after the swap. Part numbers are listed in my cam swap thread AND in your service manual...because you WILL need a service manual to do this. Torque values, sequences, etc.
Biker Bob
Exhaust System Topics
05-27-2011 09:02 AM
