New seat and fairing on Fat Bob
sbaalman, thanks for posting pics of the progress on your fairing/windshield. I just picked up a 2008 FXDF and have been looking for a 1/4 fairing for the dual headlights. This elusive item is nowhere to be found, and it looks like no one has created one yet. Some say putting a fairing on the FXDF is heresy, but I personally think something like a 1/4 fairing would look good and redirect enough air to make a difference while at speed. Your work has given me a couple ideas and I may even try to make one myself. To each their own!
I'll check back for updated pics once you have it on the bike. Good luck.
sbaalman, I like the Mustang seat you have and I have a question about it. I was looking at the same seat setup for my bike, 07 Lowrider and I was wondering how much higher you are with it over the stock seat? I am a giant at 5'4" and while I would like a more comfortable seat I do not want to change the seat height by much. Thanks...
Here are the pics of the modified fairing after making a cutout for the dual lights. It now sits about 3-4 inches lower and a little forward from the earlier mounting setup. There is almost no buffeting now (some around 70-80mph) and no pressure on my chest. I took a top-down pic of the mounting setup I made. I did buy the 1-1/4" handlebar brackets for the upper mounting on the handlebar, but the rest I made from 1/4" steel rod, rod clamps, some lag bolts, 1-1/2" pipe clamps (lower mounts are attached to the risers), rubber grommets, and bicycle seat clamps. I still need to paint the lower bolts black on the front of the fairing, and paint the rest of the mounting structure black behind the fairing.
I also installed the HD premium oil cooler when I did an oil change along with some IP-54 rated weather and dust proof fans. I still need to wire up the fans with a toggle switch. The fans are for when I'm stuck in the wonderful Vegas traffic. Will post pics of the cooler/fan setup later.
