Any Advice or Words of Wisdom Before Replacing Throttle?
Old 07-11-2010, 03:31 PM
christopheramos's Avatar
christopheramos
christopheramos is offline
Default Any Advice or Words of Wisdom Before Replacing Throttle?
I'm replacing my handlebar grips and also the control switches (because the words were all faded and worn off). I already got the left side pretty much done.
BUT, before I start taking apart the right side, does anybody have any advice for me?
The left side grib just pulls off. Pretty simple. But the throttle is a rolling grip, and I don't know if there is any special technique to getting that sucker off without f_ _king things up.
Anybody got any experience with this kind of project? Thanks guys. To show my appreciation, here's a picture of a kitten playing with a ball of yarn:
Old 07-11-2010, 03:47 PM
Denny69's Avatar
Denny69
Denny69 is offline
Front of the forum, page 2 gives full details on grip removal.
Old 07-11-2010, 05:07 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Throttle Cables
If your bike is a carb model it's easier than an EFI bike. The little brass ferrules are a pain to keep in place. Really isn't that hard at all.
Old 07-11-2010, 05:29 PM
christopheramos
I checked out the instructions on Page 2 like Denny69 said. I'd feel more comfortable if I could find some instructions with pictures, though.
Old 07-11-2010, 05:31 PM
christopheramos
By the way, Dyna Rider, my bike is fuel injected. Is the EFI hard than carb because of the ferrules?
Old 07-11-2010, 05:39 PM
christopheramos
Oh, by the way, my bike also has a cruise control switch on the throttle side. Any special warning about that sucker before I take it apart?
Old 07-11-2010, 05:44 PM
oldbiker771's Avatar
oldbiker771
oldbiker771 is offline
Nope. I keep extra brass ferules cause I drop them alot. Cheap. Lube cables while apart. Careful about pinching the wires on reassembly. Adjust as per the book. CC switch no factor.
Old 07-11-2010, 05:53 PM
dyna rider's Avatar
dyna rider
Default "Cruise Control"
There is a little plastic shoe that actually holds the throttle in place on your cruise control. NOTHING holds it on so it will fall and get lost fast. Just pay attention when you take it apart. There is also a wrist clip (it's tiny) that helps hold the cruise control **** shaft in place and if you screw it **** all the way out, it will come off the shaft.
Carbed bikes are easier because there is only one cable to deal with.
Old 07-11-2010, 06:00 PM
christopheramos
Is it really necessary to remove the air filter cover? Also, what kind of glue should I use on the new grips?
Old 07-11-2010, 06:19 PM
dyna rider's Avatar
dyna rider
Default Grips
I didn't remove the air cleaner and had no problems...I do not know about the glue. Do a search about grips and glue...I seem to remember a thread about it last year. My new grips came with set screws on the L/H grip.
fatboy1729
05-30-2018 08:55 AM
The Dali
09-16-2013 11:00 PM
Keithhu
03-06-2012 05:32 PM
MidnitEvil
08-24-2008 05:48 PM
06ClassicRider
04-21-2008 05:45 PM
Quick Reply: Any Advice or Words of Wisdom Before Replacing Throttle?
