remove stock exhaust baffles ok?
Old 07-17-2016, 09:30 PM
dlporter's Avatar
dlporter
dlporter is offline
Wow, this thread was raised from the dead twice.
  #32
Old 07-12-2017, 12:54 PM
rnrobert's Avatar
rnrobert
rnrobert is offline
Originally Posted by FBRR
I can't believe how a "little" information can be turned around!
"removing the baffles could add reversion" THIS IS WRONG
First, removing the baffle "decreases" reversion, it does not increase reversion! Reversion acts to increase low to midrange torque. Therefore if reversion is reduces ( less backpressure by definition equals less reversion!) you may feel less torque at low to mid throttle.
Less backpressure can lead to more Max. Hp. at wide open throttle, IF!!
BIG IF you can get enough fuel to take advantage of that decrease in backpressure!
" it is a closed loop so the ECM will only allow so much air or fuel regardless" This is also technically wrong!
Second! The ECM has no control over AIR into an engine ( except in the case of drive by wire where the throttle is opened by the ECM software but opening the throttle is not part of close loop control ECM control during closed loop is a fuel only correction! Not AIR). But even then the restriction to airflow is the intake ( aircleaner and exhaust) not THE ECM software control.
The ECM only attempts to maintain the correct air/fuel ratio through closed loop operation! ( by changing delivered FUEL, the ECM cannot change airflow! That is a function of restrition in the air cleaner!)
The "ECM" or more correctly the ecm software the controls fuel, can modify fuel slightly. And if you only open the exhaust, there should be enough "learning" to compensate for a little less backpressure. If you also open the intake ( aircleaner) you then would need to have fuel modified through either re-programing or an add on device!
Even with "just an open exhaust" there is a possiblity that during open loop operation at Wide Open Throttle(WOT) you can still have an overly lean condition! Some closed loop "learning" affects "open loop" fuel delivery.
But it may not account for every "speed and load" point during WOT operation! And without proper A/F ratio at WOT, you will not gain any Max. Hp. by the decrease in backpressure!
Bottom line, you will most likey not need a "fueling" device for just an open exhaust. You will most likely loss some low and mid-range torque. Without adding fuel you will not gain HP. at WOT!
I hope that allow you to make a more informed choice!
Very correct statement the ecm ecu or what ever you wanna call it is the computer and can only adjust specific af ratio in closed loop. open loop is pre programmed but luckily the epa wants open loop for as short of a time as possible ie heated o2 sensors. the ecm can and will take care of( af) ratio in closed loop with just a exhaust probably no problem at all. im actually curious how far it could adjust with a air cleaner and exhaust. everyone says you need a fuel management system but has anyone seen readings without one installed. like how lean will it be. i know a car can go pretty far to the point of a small vacuum leak untill its to far for the ecm to adjust ?
  #33
Old 07-12-2017, 11:24 PM
VoiceofReason44's Avatar
VoiceofReason44
VoiceofReason44 is offline
Just go get a thunderheader or basani road rage. Save yourself the pain and potential power loss.
  #34
Old 07-13-2017, 10:24 PM
Nemosengineer's Avatar
Nemosengineer
Nemosengineer is offline
CVPPORTRAITS
03-28-2016 06:51 PM
TJT84
08-23-2011 04:48 PM
inspector126
Exhaust System Topics
08-16-2010 12:29 AM
alrom999
05-01-2008 07:36 AM
s8norr
08-25-2007 09:53 AM
Quick Reply: remove stock exhaust baffles ok?
