2010 WG Tank Console
Old 08-11-2010, 03:20 PM
paullavery's Avatar
paullavery
paullavery is offline
Default 2010 WG Tank Console
Does anyone know if the low profile tank console on the 2010 wide glide will fit on a 2010 super glide ?
Old 08-11-2010, 08:27 PM
bberck's Avatar
bberck
bberck is offline
No the 2010 WG uses the smaller tank and 4 inch speedo.
Old 08-25-2010, 01:23 PM
paullavery's Avatar
paullavery
According to harley part numbers the 2010 FXDC & FXDWG tanks are the same !
So surely the tank console from the wide glide will fit my SG Custom ?
I know the speedo is smaller on the Wide Glide, so would look at replacing mine with a 4" speedo, with regard to electrics for ignition etc. surely they should be the same ?
Have tried a chrome lower tank console, but don't really like the look of it, it all looks a bit bulky, think the WG setup looks alot better. Suppose my other option is to look out for a WG Tank on ebay !!!
Old 08-25-2010, 01:36 PM
bberck's Avatar
bberck
bberck is offline
The Super glide custom and WG tanks were the same untill 08 when the WG was discontinued.
When they brought the WG back in 2010 they used the smaller Street bob/Lowrider tank with the 4 inch speedo.
If you look at the 2010 Specs for both Harley lists the SGC tank as 5 Gallon and the WG as 4.7 Gallon
It was the tank console set-up they used on the 08 SE Dyna that they transplanted to the new WG.
Old 08-25-2010, 01:55 PM
paullavery's Avatar
paullavery
This is all getting a bit confusing know, or maybe i'm a bit stupid !!! Could not get my local HD dealer to confirm either way, some of the guys in there said the 08 SE console would fit my SG tank as the tanks are the same, which is what you are saying about the tanks being the same until 2008, but if the 2010 WG tank is a smaller Street bob/low rider tank, how come the console set-up from the 08 SE Dyna fits ??
Or maybe I am being completely thick now & the SE Dyna and 08 WG were different ?
Please forgive my ignorance, but I just want to be able to get the look i'm after, hopefully...
Old 08-25-2010, 01:59 PM
bberck's Avatar
bberck
bberck is offline
Ya the 2008 SE used the Smaller tank as well.
Old 08-25-2010, 02:04 PM
paullavery's Avatar
paullavery
Thanks for that, it all makes sense now, will have to look out for a different tank now to get the look i'm after !!
Old 08-25-2010, 02:16 PM
bberck's Avatar
bberck
bberck is offline
As far as electronics the switch will work but will probally need new dummy lights as well. So looking at a new harness, plus new top plate and seal, your fuel pump and guts inside the tank will swap over.
Tank, Console, top Plate, harness and some odds and ends. It can add up in a hurry.
Old 08-25-2010, 02:20 PM
paullavery's Avatar
paullavery
Yeah I know, crazy when you think about it, but thats what it takes when you want a different look from the stock item !!!
Old 08-25-2010, 02:24 PM
Wonkaboy's Avatar
Wonkaboy
Wonkaboy is offline
Buy a 2006 and up Street Bob tank and the console will work !
1) Console;
Chrome is 61712-08
Black is 61732-10
2)Speedo Gasket (different than Street Bob gasket)
70706-08
3)Ignition Switch
71313-96A
4)Switch bracket
71766-08
5)Self tapping screws (4)
2501A
6)Ignition switch label
71262-05
7)Fork lock decal (minus ignition/accessory icons)
14130-06B
You also need to give them your ignition key number when you order they will make you 2 copies of your current one and you will have 4 keys ! ( No charge either )
Cheapest dealer price https://www.zanottimotor.com
Quick Reply: 2010 WG Tank Console
