HARLEY DAVIDSON HIGH SPEED WOBBLE
RE: HARLEY DAVIDSON HIGH SPEED WOBBLE
I too have experienced the wobble on my WG. Usually it's only when going 75-80+ around a curve starting after hitting a bump.
My front end is all custom...bought that way a couple years ago. Raked (+5°) triple tree, 4" over tubes, billet sliders, billet wheels, fat drag bars...
Right now I'm rebuilding the entire front end. Re-packing the steering head bearings, new orings, bushings, piston rings and fluid in the forks, and maybe progressive springs and an emulator kit as well.
Hopefully this will stabilize the ride a bit.
I wanted to install a fork brace, but I haven't found one that will work with the billet sliders I've got. I'd have to install on on the tubes. It would help, but I'd rather hold out and find one to put on the sliders.
Raking just the trees will put the trail way out of whack, and will make any bike unstable at high speeds. This is most likely the reason for the wobble. Perse performance used to have a nice rakeand trail calculator on thier site. Have you done any front end Mods? I would check everything on the front end, Wheel runout, steering head bearing adjustment,wheel bearings etc.. Mark...
ORIGINAL: markdt
Raking just the trees will put the trail way out of whack, and will make any bike unstable at high speeds....
Not much I can do about it now. If it were a performace bike...I'd be fixing that.
I have an '05 wg and have never experience stability issues going in a striaght line (have only hit 100 a couple times, but go up into the 80's regularly).
I do have the issue as stated above when going through curves and hitting a bump. I also have a custom front end, but my rake did not change. I also have Progressive 440's in the rear that are .5" shorter than stock (maybe 1", cant remember)
I installed a Tru-Track last week and have been out once for a test drive. Overall stability seemed to improve. There are a couple curves in my area that give me a problem, but I couldn't really push the test since my wife decided she wanted to go with me. I was able to hit the test curve at 60 and feel the wobble. Normally 60 is the max I can take that curve with just me on, so I think I will notice an improvement when I hit it for the first time without the extra weight.
I have Progressive fork springs, but will be replacment them with straight rate springs from Race Tech, will also be putting the catridgre emulators from Race Tech in. Plan on starting that project this week.
Once the fork springs are done I will be replacing the stock tires with Metzlers. I've got a neighbor up the street that swears the Metz solve most of the wobble issues. He rides a bagger and he can take curves much faster than the other bagger buddies he rides with.
I will report on the effectiveness of each project as I go through them.
p.s. I will have a slightly used pair of Progressive fork springs to get rid of here shortly (41mm). PM me if you are interested... $40.00
