Forward controls without losing the mid-mounts
Just want to share with all you SB / Dyna Riders what I did on my 2010 SB. I installed forward controls on my SB and love them, however, because I am only 5'7", reaching out there to the controls means that I have to ride (almost) completely straight legged. This means that I don't have a means to just rest my feet (heels down) on the pegs like I did with the Sporty I had.
Since the bike came with mid-controls, I simply just modified the pegs on them, so they wouldn't get in my way when i have to put my feet down suddenly, i.e. I made them shorter.
Here is what I did....
I took the OEM pegs, removed the rubber, sawed off everything past the inside lip (one closest to the hinge point), on the side I drilled a hole in the center and tapped it to the same tread size as the bolt on the shifter peg. I then purchased two more shifter pegs and installed them on the modified hinge and then installed the new shortened peg on the original mid-mounts.
Looks good
I saved my mid mounts to throw back on for long days but have only used them on my Iron Butt ride.
I added some Peg elevators to my forwards along with some heel rests and at 5'7 my forwards are comfrotable all day long now. Much better than the mid/highway peg set-up I started with.
EricInNCa
12-17-2013 09:02 PM
