Rear Turn Signal Disassembly
I just got a hold of a set or OWM rear turn signals that I am trying to take apart for powdercoating (chrome to Black, of coarse), but am having some trouble taking the wiring apart.
I was able to take the lens off easily, but the clip on the end of the wire will not pass through the stalk to remove it and I cannot figure out how to get the light assemblyout of the housing completely. I want to try to do this without cutting any wires if possible. Any help ASAP would be appreciated:
You have to take the wires out of the connector. Then you can get the wires out. Then take a small flat head screw driver and pry the chrome lenses out of the bullet they are pressed in but will come out. Or cut and rewire and buy some shrink tube.
You need a small, pointy piece of metal/tool to "lift" the retaining "block" inside the connector to be able to pull the cable out. It´s worth learning, will make your electrical life much easier. Check out some videos on youtube on the subject. When you reassemble i think it´s a good idea to take out the rubber "fit" that the lampsocket goes into, and put it on the socket before pushing it into the housing. If the lamp doesn´t work after reassemble it´s most probably the black wire thats not touching the spring inside, just bend the metal out against it.
i used a screwdriver to remove the socket, but i think Sumpnuts coathanger would be the prefeered way (smallest damage risk) of doing it.
Btw, are you going to powdercoat the "arm/bracket" also? I just painted one of my turnsignals black (scratch) but kept the bracket in chrome, looks cool IMO.
/Rikki
/Rikki
[quote=_Rikki_;7265690]You need a small, pointy piece of metal/tool to "lift" the retaining "block" inside the connector to be able to pull the cable out.
I use a SMALL paper clip for this, just bend one end out and wala you have the tiny tool you need to lift the clip lock and then pull the cable out.
Not to mention it is easier then soldering the wire back together. Unless you plan on using the detach kit for bags, rack or sissy bar. then you have to cut them, there is not enough room to pull the two/three wire through with the connecter ends still on. (I tried)
