What is the proper torque for the front engine mount bolts?
Old 09-15-2010, 08:06 PM
Cblast's Avatar
Cblast
Cblast is offline
Default What is the proper torque for the front engine mount bolts?
The 5/16 allen head bolts that bolt throught the frame to the rubber engine mount, what should they be torqued to? Thanks in advance!
Old 09-15-2010, 08:27 PM
bqualls's Avatar
bqualls
bqualls is offline
Default What is the proper torque value?
Hey man, My 2009 Dyna Service Manual says to tighten bolts to 21-27 ft-lbs (pg. 2-87). Love the look of your Fat Bob.
Old 09-15-2010, 08:29 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
Per the BOOK (pg. 2-1)
Front Isolator mounting bolts to front engine bracket 18-22 ft-lbs.
I stand corrected. The above specs is for the mount to engine not frame.
bqualls; has the right specs for the frame torque.
Old 09-15-2010, 09:22 PM
jordanball33's Avatar
jordanball33
jordanball33 is offline
either way at 22 lbs you should be fine.
Old 09-15-2010, 11:38 PM
Cblast's Avatar
Cblast
Cblast is offline
Thank you sir! I really appreciate that. The dealer used NO loctite on anything when they did the 1k service, so now I am going back and re-doing everything myself. Thank you for the compliment too, I have since ditched the mirrors, put on smoked turn signals and done a few other little things to try to subtley improve the look. I love this bike.
jmn1960
08-21-2015 01:31 AM
st john
08-12-2008 10:53 AM
jengah
Shovelhead
08-09-2007 10:57 PM
Pipedope
07-11-2007 12:27 AM
Brackneyc
07-02-2007 01:15 AM
Quick Reply: What is the proper torque for the front engine mount bolts?
