Front Brake-Light switch
Found out today that the brake-light switch controlled by the front brake lever on my '03 WG may have issues.
The guys I ride with (we just got back from the Vegas BikeFest) have been telling me that the brake light flickers and goes on/off randomly - they don't know when I'm actually hitting the brakes. It does NOT go OFF if I am actually on the brakes.
Jiggling the lever just the slightest amount up/down, while the bike is parked (without applying the brakes at all) causes the brake light to come on. Getting on the freeway with even minimal wind seems to trigger it, as does riding over bumps (but there does NOT seem to be an intermittent in the wiring under the seat, because it doesn't seem to misbehave if I sit on the bike and just move around, or ride slowly in city traffic).
Is there an easy fix for this or am I looking at significant time and money (meaning: replacing parts - is this the switch itself going south or is there something easy and obvious I'm missing)? The little C-ring is still there, nothing appears amiss, just looking at the setup.
TIA-
Bob
TIA-
Bob
Something is closing the circuit that brings on your brake light. It will either be an intermittent short-circuit SOMEWHERE, or possibly the "micro-switch" assembly that your front brake lever engages is out of wack (ie. being too close/far) and is getting actuated. From what you said about "jiggling" the front lever causing it, I would focus on that. Perhaps you'll need a new assembly that is "tighter".
Hope that helps.
Hope that helps.
Have you done anything to your handlebars that involved taking your right hand controls off?
If you take the controls off the right side without using a wedge between the brake lever and the housing, it can cause damage like you described. Don't ask how I know this?
+1 on the wedge, you can also adjust the switch in the master cylinder/throttle. When you pull on the brake lever it moves away from the switch activating the light. The spring in the master cylinder has to be pushing the plunger all the way out to push the lever against the switch. The rear brake system uses a pressure switch versus mechanical.
Yes, I have replaced both levers with the contrast-cut black ones. However, I DID use a cardboard wedge as they said in the directions, and it didn't start happening until several weeks after I changed them out. Were you able to solve it by just taking it apart and re-installing?
Mine apparently had been acting strange like yours for quite a while before it was called to my attention by the dealer. I'm never behind me when I put the brake on.
Dr Bob, when you get a chance, swing by the dealer and pick up a new switch. We can put it in when we do the motor. Or you could have Drew (Dr V Twin) put it in for you (That ought to be fun to watch)
In the meantime, I guess you wont have to worry about anyone tailgating you
You'll have to excuse me. I'm on my 4th pot of coffee, and the caffeine's getting to me
edugatyr
04-08-2012 01:39 AM
