Front Rotor Bolts - switch to Allens
Old 11-17-2010, 10:11 AM
Kev_England's Avatar
Kev_England
Kev_England is offline
Default Front Rotor Bolts - switch to Allens
Hi guys,
Im in the process of changing out all my Torx to Allens or 12-point. I've changed just about all I can see except for the front rotor bolts. They seem to be specialized bolts with a "Sleeve" towards the head. I cannot find replacements--except the HD Torx jobs. Apparently for 2007/8 FXDs with cast wheels they used this odd bolt.
Anyone know where I could get these bolts in Allen or 12-point head?
Cheers.
Old 11-17-2010, 12:15 PM
QehQeh's Avatar
QehQeh
QehQeh is offline
I hate torx bolts, but why spend money to replace bolts that might get turned two or three times during the life of the bike?
Old 11-17-2010, 12:21 PM
Mascman's Avatar
Mascman
Mascman is offline
I agree...mark them up as "specialty bolts" and ride on!
Old 11-17-2010, 12:29 PM
fixxr's Avatar
fixxr
fixxr is offline
The thing with the rotor bolts is if they stick out too far they rub!
Old 11-17-2010, 01:18 PM
Kev_England
true enough Fixxr! But, there's actually low-profile 12-point bolts available. They look nice too. Trouble is, I can't find them for the "sleeved" version that I have. Allens would actually fit, but the clearance to the forks (or swing arm in the case of the rear rotor) is diminished.
Old 11-17-2010, 01:21 PM
Kev_England
True too. I like wrenching on my ride and am always in the middle of some modification or other. My bikes are never "finished" so Im always tinkering with them. For me, I like the notion of always Knowing I just need to turn to me SAE wrenches or Allens (or mm version for some things like the forks).
Plus, my bike tool kit is made smaller when on the road.
Come on! surely someone out there has De-Toxed ...opps De-Torxed their 2007 or 08 fxd!!!
Old 11-17-2010, 01:31 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Originally Posted by Kev_England
...low-profile 12-point bolts....
Send an email to U-bolts and ask if they have the bolts you need on stock....
Old 11-17-2010, 03:26 PM
NoLongerAmember's Avatar
NoLongerAmember
NoLongerAmember is offline
First off you are supposed to replace them each time you remove them. They also locate the rotor so the shoulder needs to be the correct diameter and they need to retain the spring washers as well. I would leave them alone unless you can find an exact replacement.
CB
Old 11-17-2010, 03:33 PM
Foxster's Avatar
Foxster
Foxster is offline
Be a tad careful what you replace them with. Its tempting to use stainless steel but the standard s/s isn't strong enough for this. You need the right grade of steel for this application or you risk having the bolts shear off.
Old 11-17-2010, 03:49 PM
parts eeter's Avatar
parts eeter
parts eeter is offline
Sorry Kev I dont have the info you are looking for. I did however just replace my stockers with the upgraded HD chrome bolts to match my rotors. They fit nicely though.
Quick Reply: Front Rotor Bolts - switch to Allens
