Help - Cross threaded bolt?
1st… Love your quote
Hey if I was going to skin that cat… I’ll take my lever and myself to the local hardware store and find a longer slightly thinner/longer bolt and get matched sized nut and washer and install… Or you could get a tap and die set to re-cut the correct size and get a new bolt…. Or you my need to make it slightly larger and get a new bolt for shifter and you should be good to go. ………………… Good Luck
Need to run a tap through the shifter to clean up the threads. If that doesn't let a new bolt hold it securely, drill it out and cut all new threads for a little larger bolt. If that's not an option, based on how much metal is around the hole, get a helicoil installed. The other thing is to drill all the way through and use a bolt and nut as the previous post mentioned. So, you have some options, just need to use the one that works best for you...or buy a new lever and be more careful installing it. lol
Drilling it out for as larger size wont work too well either, unless your shifter shaft can handle a 3/8ths dia bolt run through the slot (its gonna be close). Helicoil may be your best fix, but you'll have to blind side it, which aint easy if youve never done it before.
a man's gotta know his limitations
Shift levers are forged steel--not aluminum. And they require the original size bolt--not a larger one--as they are trapped in a groove in the shift shaft, presumably so the lever won't fall off, even if the bolt loosens. Replace the bolt w/ a brand-new original size, after running a tap through the hole. If the threads are too messed up, either install a Heli-coil insert or replace the lever.
