leak around crank sensor
Old 11-19-2010, 02:54 AM
midnitewolf's Avatar
midnitewolf
midnitewolf is offline
Default leak around crank sensor
It looks like I have a small leak where the crank sensor comes
thru the case , does anyone know if there is an o'ring on the sensor
or if you have to replace the complete sensor and do you have to
remove primary covers to replace it .
I really need to buy a manual
UPDATE :
After a second look it is leaking where the stator wire comes out of the
case , any fix for this other than replacing the stator
Old 11-19-2010, 06:18 AM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
It has an o-ring on it.
Old 11-19-2010, 06:41 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
I had my crank position sensor go bad on me about six months ago ... it wasn't just the o-ring ... the plastic housing had broken up and about half of it was gone ... no way it would have held an o-ring in place with what was left of it ....
You shouldn't have to remove the primary ... there's a plug over on the right side of the motor, unplug it there and remove the one bolt holding it into the crankcase ... as I recall it costs somewhere between $50-$60 ....
Pretty easy fix, but don't let it go too long ... mine started spewing oil while I was on the freeway ... not a fun time ...!
R/
'Chop
Old 11-19-2010, 06:42 AM
Mike T's Avatar
Mike T
Mike T is offline
You don't have to remove anything but the two screws that hold the sensor and pull it out.Check to see if the screws are loose first.
Old 11-19-2010, 08:00 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is offline
Sponsor
Loose screws on a Harley..? Yep first step..
__________________
www.Captain-Itch.com
Old 11-19-2010, 09:52 AM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
Also want to make sure the leak isn't actually out of the stator wire. My 2006 Street Bob started to seep oil out of there this summer. The fix is to replace the stator so until the leak gets worse (just a few periodic annoying drips now) I just wipe the bike down and wash it a little more often.
Old 11-19-2010, 03:33 PM
midnitewolf
Old 11-19-2010, 03:43 PM
texas_speed_freak's Avatar
texas_speed_freak
texas_speed_freak is offline
There is a fix, but it involves removing the stator and using a sealing compound like yamabond or Threebond 1194 and putting it around the plug, then pushing it back trough. Still alot of work so if its not a bad leak i wouldnt worry about it.
FYI, dont try to silicone the outside because it wont stop the leak and will make it look ugly as H**L.
Old 11-19-2010, 04:28 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
This may not be the technically best way to do things but, I cleaned mine (stator wiring) good with carb spray, cleaned good, then coated the area with black silicone. Leak fixed, for the price of a tube of silicone. After you get the silicone on it, spit on your finger and smooth everything out so it won't look like caca. 103k and still no leak. I did it about 60k
Old 11-21-2010, 06:37 AM
midnitewolf
What's a good cleaner to use that won't stain or mess up
the black cases
Quick Reply: leak around crank sensor
