Rake on Wide Glides
Old 12-14-2010, 09:49 AM
8541hog's Avatar
8541hog
8541hog is offline
Default Rake on Wide Glides
So, I have found differing answers online and looking for the definitive answer.
What is the rake difference between the 05 Wide Glide and the 49 mm Wide Glide front ends? Just need to know the actual triple tree rake.
I would like to do a swap to 49 mm but do not want to lose any rake, gaining a degree or 2 would be fine though.
It is obvious the newer (06-up) WG's have more total rake, but I also know they added some to the frame.
Old 12-15-2010, 06:10 AM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
'06 DWG: 34-deg. in the frame + 2-deg. in trees = 36-deg. total rake.
'04 DWG: 32-deg., frame only.
Old 12-15-2010, 06:28 AM
8541hog's Avatar
8541hog
8541hog is offline
Thanks Kelly. Doesn't the 05 have 2 degrees in the trees also?
Old 12-15-2010, 06:45 AM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
Pretty sure they do. I put a set of older 41mm WG trees on my super glide and it definatly raked it out more.
Old 12-15-2010, 07:02 AM
8541hog's Avatar
8541hog
8541hog is offline
Thanks Red
Old 12-15-2010, 07:31 PM
strongwood's Avatar
strongwood
strongwood is offline
Alright
I am lost, new owner here.......what do I have on my 99 Wide Glide?
also, what are the MM referring to? the size of the tubes?
Old 12-15-2010, 08:17 PM
Yasky1997's Avatar
Yasky1997
Yasky1997 is offline
Originally Posted by strongwood
Alright
Not sure, but I think you have 33 deg rake total. I don't think any is in the trees but I am not sure. As far as the "mm" that is refering to the fork tube diameter. It has changed several times over the years.
Old 12-15-2010, 08:22 PM
strongwood's Avatar
strongwood
Thanks Yasky
I feel kinda dumb looking at all the knowledge here.
Like someone said, "he doesn't know that he doesn't know"
I didn't know that there is so much to learn here until I read something and then the knowledge hunger kicks in.
Thanks again for the info
Old 12-15-2010, 08:28 PM
Yasky1997's Avatar
Yasky1997
No problem. This forum is full of very knowledgeable people, who are willing to share. Congrats on the new bike.
Old 12-15-2010, 08:55 PM
8541hog's Avatar
8541hog
8541hog is offline
I believe there is some rake in the older WG trees as well, not sure about the 90's since I bought my first WG in 01, but the frame of the WG and Low Rider are usually the same and the additional rake was in the trees. Could be wrong, but I believe that is true.
Quick Reply: Rake on Wide Glides
