Road King rear fender on my '05 FXDCI
Last year I put a Road King frear fender on my 05 Dyna so I could use a tombstone tail light. I used spacers as there was over 1/4" gap on each side. The struts are 8" apart. Is there a similar fender that will fill the 8" space so I can run a fatter rear tire. Want to install a FatBoy rear rim with fat tire.
Harvey -
(or anyone who's widened your rear fender struts) ... was looking at possibly widening my rear fender struts a little, but when I looked from the rear with the fender off, it appears I only need to bend the left one ... that is, they appear to be off-center to the right ....
I don't want to just 'spread them' because the right one is further from the center already ....
Has anyone else noticed that ...? And, if so, how do / did you just 'spread' one side ...?
R/
'Chop
R/
'Chop
Next time you are around several different Harleys slide your hand between the rear tire and fender on both sides. (Don't do this to a stranger's bike. I think you will find that one side is tighter than the other. On my Shovel it's tight on the right. But it has a Sturgis belt drive setup with belt drive swingarm. Done that in '95. My Street Bob was also tighter on the right before I started the process. First we spaced the rear wheel and tried to center it by lining it up with the front of the struts. It's hard to get a good measure. I think we got it about a 16th off to the right of center. Which is closer to center than it was stock. Then the struts were cut and squared to the wheel.
Rick101285
02-01-2011 08:34 PM
