Help! will the Avon 180 tire fit my 2009 FXDC?
Old 12-29-2010, 11:53 AM
wattsupFXDC's Avatar
wattsupFXDC
wattsupFXDC is offline
Question Help! will the Avon 180 tire fit my 2009 FXDC?
I am making my first tire replacement on my 2009 Dyna Glide Custom. I only got 4K on my first tire. I wanted to replace with a 180 tire to fill in the rear fender. Has any put the Avon Storm 180/55/R17 on their stock spoke rim? or do you have another brand suggestion. I called the stealer for the Screamin Eagle 180 which is $309 in SoCal. Will a 55 fit or do I have to go with 60?
Old 12-29-2010, 11:59 AM
odd_child4life@hotmail.com's Avatar
odd_child4life@hotmail.com is offline
will a 180 fit in your rear fender? yes absolutely.... HOWEVER, it will NOT fit with the stock final drive belt. it has to be replaced. the kit harley sells seems like a great deal if you can install it yourself that is. the kit even comes with a 180 in the kit. but without going to the slimmer drivebelt i wouldnt do it. as soon as that belt starts to frey on the edge... its only a matter of time before it rips like paper.
Old 12-29-2010, 12:08 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
that is true for a 200 series (or you can use a spacer) but a 180... it will fit no problem wiht no mods. just put on the tire, done... i would sugest that you watch your wires under the rear fender
Old 12-29-2010, 12:20 PM
nkauf21's Avatar
nkauf21
nkauf21 is offline
A thinner drive belt is not needed to fit a 180 on a '06 and later Dyna. The kit Harley sells only comes with the SE 180 tire and some fender strut brackets that aren't needed. The main problem is the stock wheel is 4.5" wide which is not wide enough for a standard 180 tire. The only tires available that are designed for a 4.5" width rim are the SE 180 and the Pirelli Night Dragon. All others will need a 5.5" width rim. I'm running an 18x5.5 with a Metzler 180 with no other mods to make it fit.
Old 12-29-2010, 02:17 PM
Sumpnut's Avatar
Sumpnut
Sumpnut is offline
Yea what he said..the Avon 180 is not made for your standard rim..If you like avon get a 170/60x17 Avon Storm.that'll fit.
Old 12-29-2010, 03:04 PM
RAWHIDE07's Avatar
RAWHIDE07
RAWHIDE07 is offline
Received 37,189 Likes on 12,877 Posts
Wrong.You do not have to replace the sprocket or belt with the HD 180 wide tire kit p/n 43768-06.The list price is 279.95 which includes the Dunlop tire.
Old 12-29-2010, 06:58 PM
Reichpapers's Avatar
Reichpapers
Reichpapers is offline
Not much to the brackets either. Instead of your wires coming out of the old brackets as they do, the new brackets basically bends your wire 90 degrees and feeds them out of the back center of the bracket so they do not stick above the bracket. I'm having the kit installed right now, the clearance from tire edge to fender is tight though...can't get a finger in there. Looks sick though.
Old 12-29-2010, 08:44 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
I currently have the SE. 180 installed on my 06 Bob without the wide tire kit.Most Harley dealerships will not do the install if you don't buy the kit.At the time I had all my wiring ran outside the fenders so they went ahead and did it but now I have the stock wiring and it works fine.What you can do is just take the wheel in by itself and they will do the install.I also cleaned the inside of my fender real good and taped my wires to the inside of the fender with aluminum duct tape.
Old 01-27-2013, 10:14 AM
molson9's Avatar
molson9
molson9 is offline
Default 180 Tire
You need to do the light relocation back to the tail light, I have had Mech and Dunlop 180's on my 08 FXDC with no problem. Make sure that your wiring for your rear lights is securely up in the fender. Other wise your tire will burn them in two. I have also been using the balancing beads, but that is a whole nother subject.
good riding
Old 01-27-2013, 05:38 PM
arkstreetbob's Avatar
arkstreetbob
arkstreetbob is offline
The Avon 170/60r-17 and the 180/55r-17 are shorter than the stock tire. It is like doing the 30t pulley change. I have the 170 on my bike and like it.
Quick Reply: Help! will the Avon 180 tire fit my 2009 FXDC?
