2009+ Street Bob fender, Closing the gap?
Old 01-02-2011, 03:27 PM
n0code's Avatar
n0code
n0code is offline
Originally Posted by Vinsil
I think this eliminates the blocks/lower shocks:
I have tried 11" shocks in the past but it was too low, stiff and handling went to hell. I'm also reluctant to use lowering blocks as my girl likes to ride with me from time to time, it just doesn't seem like a safe option.
He wants the bike to still ride good and I agree with him, lower shocks and blocks suck when it comes to handling and ride quality.
Yea well, modding motorcycles is not a good idea for those of us who sufer from the human condition, eh? haha
Old 01-02-2011, 03:33 PM
07bobber's Avatar
07bobber
07bobber is offline
Saddlebags should fix the gap haha
Old 01-02-2011, 06:21 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by n0code
I'm looking for a way to close the gap between the rear fender and wheel without using lowered shocks or lowering blocks.
I thought about it, and would it be possible to pull off the fender, close up the strut mounts with some bondo, drill in some new mounds an inch or so higher and effectively bring down the fender?
STOP!
If you lower the fender (forget Bondo), your tire will hit unless you reduce the suspension travel proportionately.
Old 01-02-2011, 06:34 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
OK on the cheap, a taller profile tire will close that gap a bit. You may have to study some to find a taller profile tire that'll fit your rim but that's the solution.If you want to spend more go to an 18" rear wheel.redrilling and remounting the fender might work but that's allot of work.Also in place of Bondo or welding I've had real good luck with JB weld filling holes.Another idea is to just go to a longer fender something like an FLH or Road Glide fender will totally hide that gap.
Old 01-03-2011, 01:13 AM
parts eeter's Avatar
parts eeter
parts eeter is offline
I went to an 18 rear wheel and 21 front. Now I have plenty of clearance for cornering, and less gap at the fender. The extra cornering clearance I gained from the larger wheel combo has provided me enough confidence to go with a 11.5 inch shock. I feel this will give me the best of both worlds. Sufficient corner clearance and with high end 11.5 shocks I am hoping to retain or improve ride quality also.
Old 01-06-2011, 01:12 AM
n0code's Avatar
n0code
n0code is offline
I'm digging the 18 inch rear wheel idea. I'm going to have to stalk ebay a while for that one.
On a side note, I think I may start a search for a pre 2009 fender, or just a superglide fender.. they look nice
This picture is with 12.5 inch shocks to boot
Old 01-06-2011, 02:22 AM
parts eeter
You prolly wont find one on ebay, but its an easy deal to have a 18 hoop laced up to your hub.
Old 01-16-2015, 07:59 AM
Russell D Rogers's Avatar
Russell D Rogers
Russell D Rogers is offline
Stage IV
my burly shocks work great
Old 01-16-2015, 10:50 AM
enodrano's Avatar
enodrano
enodrano is offline
In my opinion the best way to lower the bike is with the shocks/springs. I believe the stock Street Bob rear shock is 12". If 11" is too low then try a 11.5" shock. Look into the Wide Tire Kit from Harley. It adds a 180mm wide rear tire that helps fill out the fender. Handling will get worse when you lower the bike but you can help alleviate that with a steering stabilizer.
EasyMoney1027
09-27-2011 11:18 PM
CSS_FXD
07-22-2011 01:57 PM
bberck
07-02-2009 12:02 PM
Clove88
03-24-2009 10:17 AM
alank
11-17-2008 10:42 PM
Quick Reply: 2009+ Street Bob fender, Closing the gap?
