V-Rod wheels on a Dyna
I was wondering if anyone has put these V-Rod wheels on a dyna? I have a 08 Low Rider and want these wheels and dual Brembo brakes in the front and a Brembo in the rear. What would I need and what works?
Thanks for the help
http://cgi.ebay.com/ebaymotors/180-V...item4aa52408e1
Thanks for the help
I slid the front 49mm V-rod forks with the Brembos and wheel into my 08 Low Rider. Also modded a Street Glide rear Brembo and mount with 11.8 inch rotor to go on the back. EBC double H pads in all the calipers. It's a two finger stopper now.
I sent you a PM, feel free to send back a phone number or call me to discuss details. John
The rear V-Rod wheel has a floating hub and is very wide so a fender change and strut cutting and widening would be necessary. Probably a chain drive or front pulley offset would also need to be done. Mounting a rear V-rod wheel would be permanent (cut and weld) modification of your Dyna undertaking.
