Rear Tire Size?
Rear Tire Size?
I'm getting ready to change my wheels to some PM Torque's. They should look sweet. My question is that I currently have 16's on the rears, but the new PM rear wheel is an 18. Current tire size is 150/80/16. What would be the correct sized replacement for the rear, only in an 18?
Not that it makes any difference, but the front is a 100/90/19.
Thanks.
Thanks.
another forum member found this site. its a great site to have in your favorites
http://www.hdwheels.com/Product.htm
Am I understanding this correctly?
On a side note, I haven't contacted PM just yet, but will if necessary.
Just what I was looking for. According to this, the largest I can go would be a 160/60/18 without any modifications. I thought that to get the sidewall height, in this case, you'd take 60% of the tread width 160, and that gives you the height in mm. So if that were the case, then the height would be 96mm? Same math, I have 117mm sidewall height with the 150/80/16, which is taller.
160x.6=96...
if your still feeling ify i would definitaly get in touch with pm for some support before spending a couple hundred bucks on the wrong size tires.
