Sportster 48 front end
Old 01-28-2011, 11:51 PM
Dynaglide68's Avatar
Dynaglide68
Dynaglide68 is offline
Default Sportster 48 front end
Is that a wide glide front end ( Triple trees ) on the 48 model ? i want to run the 16 inch tire and rim on my street bob , i guess the trees on the 48 are the same as the wide glide and fatbob ?
Old 01-29-2011, 12:31 AM
maxxod's Avatar
maxxod
maxxod is offline
No they are not the same, the Street Bob has mid glide trees with 49mm fork tubes
The 48 has mid glide style trees, with 39mm fork tubes
There is a thread on here about this conversion....Ill see if I can find it for you.
Old 01-29-2011, 12:33 AM
maxxod's Avatar
maxxod
maxxod is offline
Talking
Here you go...check this out:
https://www.hdforums.com/forum/dyna-...treet-bob.html
Good luck!
Old 02-02-2011, 03:33 PM
Dynaglide68
Good luck!
Thank You !
Old 02-02-2011, 04:23 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is offline
I would think a Fat Bob front end would be easier and look better with the 49mm forks and dual brakes. I just don't like the Fat Bob rear.
Old 02-02-2011, 07:47 PM
Sumpnut's Avatar
Sumpnut
Sumpnut is offline
Xbones 16" front rim laced to the SB'S hub,fit the 130 tire a la Xbones,custom fender and Bobs yer Uncle...fits with the standard Street Bob midglide forks.... just !
DickDanger
07-22-2023 08:22 AM
Dkestner9
06-27-2018 12:33 AM
jettchoppers69
01-07-2013 09:46 PM
Sith66
10-05-2012 06:52 PM
Iron lHorse
01-04-2012 09:49 PM
Quick Reply: Sportster 48 front end
