Dyna WideGlide - Cranks, Won't Start
Old 02-23-2011, 09:15 PM
racmas's Avatar
racmas
racmas is offline
Stage II
Default Dyna WideGlide - Cranks, Won't Start
My '06 WideGlide will not start. It cranks, gets fuel, but will not start. Was stored for 3 months, started fine when I put it in winter storage. Fuel was winterized, battery was left out of the bike on a trickle charger. Reinstalled the fully charged battery, but doesn't seem to get spark. Any help is appreciated.
Old 02-23-2011, 10:08 PM
8541hog's Avatar
8541hog
8541hog is offline
How did you check for spark?
If the battery is not putting out at least 12v, the ECM will not allow it to start. At 11.9v it kills the coil. Did you check all fuses?
Old 02-23-2011, 11:35 PM
dsiltman's Avatar
dsiltman
dsiltman is offline
My low rider did the same thing. I peaked the battery in the bike and it started right up. If that is your original battery it may be getting tired.
Old 02-24-2011, 07:23 AM
racmas's Avatar
racmas
racmas is offline
Stage II
Had the Battery on charge and out of the the bike for 4 to 5 mouths
I did notice that after 15 to 30 sec Battery is low after trying to start
I used a spark plug teaster at the wire hook up to a ground saw no spark held the wire in my hand got no shock so must be no spark
And it was on a slow amp trickel charger and yes it the battery that came with the bike in 2006 and last after winter storge i had a hard time starting the bike a few times maybe it is time for a new battery if its down to 11.5 or less in a few sec
Old 02-24-2011, 07:25 AM
8541hog's Avatar
8541hog
8541hog is offline
Sounds like time for a new battery. Winter is a battery killer if you are not able to ride regularly.
Old 03-30-2011, 08:41 AM
Shepherd348's Avatar
Shepherd348
Shepherd348 is offline
Stage III
Does this low voltage cut off of the coil work the same on older bikes? I've got a 1998 Wide Glide and have the same problem. Turns over, gets gas, no spark.
Thanks for your input. The weather is too nice to have it sitting with the seat off.
Old 03-30-2011, 09:12 AM
8541hog's Avatar
8541hog
8541hog is offline
I am not sure what year it started. I think it started with the TC88 but not positive.
Old 03-30-2011, 09:30 AM
Shepherd348
Stage III
Thanks for the feedback, but I'm a newbie to the HD. What year was the TC88 introduced?
Old 03-30-2011, 09:36 AM
8541hog's Avatar
8541hog
8541hog is offline
Your 98 should be an EVO, the TC88 Dyna's started in 99 as I recall.
Old 03-30-2011, 01:55 PM
Shepherd348
Stage III
Ah, missed by a hair. Thanks again. I'm recharging the battery just to be sure. Assuming that at full tilt 12-volt boogy it still won't start. Is there a way to determine if it is a coil or ignition module issue?
Thx, Shep
Quick Reply: Dyna WideGlide - Cranks, Won't Start
