Just Installed Cycle Shack Slip Ons. Remap?
Old 03-04-2011, 07:57 PM
BigMarkStreetBob's Avatar
BigMarkStreetBob
BigMarkStreetBob is offline
Default Just Installed Cycle Shack Slip Ons. Remap?
I just installed cycle shack slip ons on my 09 Street Bob. It seems to run great. Do I need to remap? Could it cause damage if I don't?
Mark
Old 03-04-2011, 08:30 PM
HD4SV's Avatar
HD4SV
HD4SV is offline
Did the same thing on my 2010 fxdc and the answer is No. You do not need to unless you change out the air filter as well. I was told this by the stealership. I think you made a wise choice in the Cycle shacks, they sound great.
Old 03-04-2011, 08:46 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
Why if the ir filter too? I did both on my 06 and I believe the factory system compensates for the change unless you start changing more in depth system components. With the earlier manganelli system you had to. But not so much on the newer bikes unless you go to extremes with drags and a velocity stack unless you develope a miss
Old 03-04-2011, 08:51 PM
Topspin's Avatar
Topspin
Topspin is offline
No.
But if it's running a lil lean and you want to fatten it up a bit, try a set of
Xied's. Inexpensive and a 15 minute install.
Some reading material ---> http://www.nightrider.com/parts/
I ran that setup on my last bike. Ran great. However there's no replacement for a full stage one upgrade when the wallet allows.
Old 03-04-2011, 09:07 PM
BigMarkStreetBob
Thanks guys....I thought that I was fine but I wanted to double check. It is a pretty new bike so I didn't want to mess it up. BTW I got the cycle shack slip ons new from ebay for 95 bucks shipped. I am very happy with them.
Mark
Old 03-10-2011, 06:49 PM
Brackneyc's Avatar
Brackneyc
Brackneyc is offline
Mark
Which ones did you go with. Thanks
Old 03-10-2011, 06:54 PM
dtone72rss's Avatar
dtone72rss
dtone72rss is offline
i would.
Old 03-10-2011, 06:58 PM
RAWHIDE07's Avatar
RAWHIDE07
RAWHIDE07 is online now
Received 37,087 Likes on 12,848 Posts
Originally Posted by Topspin
No.
That is a good combo,I run the xied's and screaming eagle slipons,runs great and the plugs look perfect.
Old 01-08-2014, 11:52 AM
Ljeetu's Avatar
Ljeetu
Ljeetu is offline
Stage IV
Hi Mark, I have just installed Cycle Shack Slip ons on my 12 Street Bob today and would like to ask you Has your biked worked fine without making any changes on your intake or dyno.? because some other threads say that its imp to do Stage 1 upgrade to Air filters.....Appreciate if you can let me know
Old 01-08-2014, 07:08 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
No.
What he said
Quick Reply: Just Installed Cycle Shack Slip Ons. Remap?
