starter jack shaft bolt problem
Old 03-06-2011, 10:28 AM
QuickSilver74's Avatar
QuickSilver74
QuickSilver74 is offline
Default starter jack shaft bolt problem
finally got my new inner primary and am putting everything back together but i have ran into a problem. i have the sleeve on the rear side of the inner primary over the starter splines but when i try to put the parts of the jack shaft that are inside the inner primary together with the sleeve i do not have any threads making contact to tighten the small bolt that holds the jack shaft to the starter. i know the starter pushes the jack shaft out about an inch or so when you hit the start button. is there a way to make it push the shaft out enough so i can get the bolt started without the starter spinning over?
Old 03-06-2011, 11:13 AM
QuickSilver74
found the problem
Old 03-20-2012, 09:49 AM
Robert Evans's Avatar
Robert Evans
Robert Evans is offline
Stage III
Default same problem
Can you tell me what you did to get bolt to thread. Mine doesnt seem to want to reach threads on starter either. I know i have everything installed correctly. Thanks
Old 06-15-2014, 06:20 PM
BM05FLHT's Avatar
BM05FLHT
BM05FLHT is offline
I know this is an old post - brother inlaw having same problem - old bolt is smaller than the new starter, did Moco make a change and go to a larger bolt?
Old 03-03-2020, 10:14 AM
Chris Clarke's Avatar
Chris Clarke
Chris Clarke is offline
Stage II
same problem. Put everything back together and now I can get the small bolt to reach the r threads on thestarter shaft.
Old 03-03-2020, 10:27 AM
Chris Clarke
Stage II
Having same problem. Put everything back together and nowcan't get small bolt to start in starter shaft
Old 03-03-2020, 11:39 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
Use the bolt from the different year.
But seriously dude this thread is 9 years old
99creation-evo
07-31-2010 09:54 PM
terrapin88
EVO
07-02-2010 02:19 PM
JustDave71
05-26-2010 12:54 PM
frantheman39
EVO
08-16-2009 07:09 AM
CQuinn
Custom Models
09-26-2007 10:58 PM
Quick Reply: starter jack shaft bolt problem
