Handlebar wiring just plain beat me up!
True about the thicker weedeater line bending around the curves. It also won't break like fishing line, also doing it this way, you've always got a line through the bars so if you have a wire come untaped or something it isn't a big deal to retape it and start back over. If you have to try to thread a new line or wire through after you've already got few in there you're screwed.
Thanks again
I would be very cautious of this. If the bars were not made specifically for internal wiring, some of the tubing might have sharp edges inside the bars, at the welds. This might be what is giving you problems. I would pull a single wire through and yank it around some to see if it's getting chewed up somewhere along the line. If there are sharp edges, even if you get the wires through, vibration might cause one to get cut and short out sometime in the future.
Update: I got the broken wire out and was able to wire the clutch side containing the 8 wires. I did it just as Jstreet said and it worked great. My concern now is since there is no tape around the wires do you think the vibration will nick the wires and cause problems down the line. It is something I have thought about since I got the bars but I don't know how bad the welds are on the inside. The wires came through pretty clean and I taped up where they go into the bars on the top where I drilled and will put some protection on the bottom at the other drill point. Just don't want to get stranded down the line. I know this will go both ways but any input will be helpful.
Thanks
Kevin
Thanks
Kevin
Thanks
Kevin
Thanks
Kevin
