Photos of holes to drill for 'bar internal wiring?
Hello chaps,
So I've decided the apes on my Street Bob have got to go. I've bought a pair of genuine Sportster 'bars and they have control dimples but no internal wiring holes. Can anyone direct me to a photo of a dimpled drilled 'bar so I can see where the hole has to go and how big diameter the drill needs to be?
Cheers.
Cheers.
i just did this last nite, check my post here:
https://www.hdforums.com/forum/8016664-post12.html
couple of noteworthy things I found while searching and doing this:
- 5/8" is the most common number i've seen for the 'in' holes, it might be tight but i wouldnt want to go any bigger (lengthening the hole along the dimple might work if it seems to tight)
- have someone mark the spot where you want the wires to come out, hold the bars in place on the bike while they do this
- the 'out' hole i made is slightly larger than the diameter of the dremel's heavy duty cutting disc
- the grinding stone bit for the dremel works wonders for deburring
- make sure you've deburred it a lot BEFORE you poke your finger in to check
good luck and enjoy!
I'm going to swap the throttle and clutch cables for 2010 Wide Glide versions but H-D only list the same set of wires for all the Dynas so I guess you can just stuff 'em more into the frame.
thone
09-23-2010 04:34 PM
