Dyna Floorboards (not FXDP...)
Does anyone have any experience with these boards from Drag Specialties and numerous other suppliers on a post 2006 FXD? Other retailers say they fit almost any standard Clevis mount but i keep seeing that prefixed with "for FXWG".
ADJ F-BOARDS W/DAMPER [DS-254412]
DRAG SPECIALTIES
Appears In:
They "seem" a reasonable alternative to proper FXDP boards and the adjustibilty factor is big plus for me, but I'm wondering if the Clevis mount is going to be under excessive stress being the only mount point, and if it is up to the task of holding the board plus the weight of my not insubstantial fat bastard legs. A footpeg is substantially lighter, and depending on how the board is mounted the stress directions at the Clevis would be far different than a peg mount.
Appreciate any first hand info.
8's
DRAG SPECIALTIES
Appears In:
- FATBOOK 2011 · Printed Catalog Page #1067
- FATBOOK 2011 · Printed Catalog Page #1075
- OLD BOOK 2011 · Printed Catalog Page #224
8's
I have seen those on eBay for consideriably less, i have had no actual expereince with them. I was interested in the FXDP boards, but not willing to part with 400 for them.
As an FYI, I was able to pick up some HD heel rests that have been discontinued. Thank you eBay. They were 60 bucks, they work. Not excellent, but not bad either. You may want to consider.
good thread here: https://www.hdforums.com/forum/dyna-...oorboards.html
Wyatt i believe make a kit now, but its pricey ($400 +)
what has got me interested in these is the adjustability of them which is a much bigger hassle with the FXDP style setups.
I am gonna dig up a set of these to try out, for that price they're worth it I think unless someone has been there done that and has a horry story to go with it.
I have used this company before abnd they have boards that look the ones you posted...for much less.
http://www.kcint2.com/category/ff2_gripspegshandlebars/
I tride the $35 ones and they are a weird angle for the driver pegs...would probably work on the rear.
This is actually the ones I thought may work:
http://www.kcint2.com/product/50-440...80-AND-UP.html
I used a similar style board but due to being vertically challenged I came up with a rigid mount spanning the mid peg frame mount and forward control frame mount points just using the boards. The original product was fine but not for me. You will need to insure you can get all parts tight!! and all should be fine. (please see pic), sorry but I deleted my detailed pics from photobucket and cannot access them while on duty. My forwards are moved rear wards from original points and are Independent from the boards. The clevis mount points on my forward controls have been cut off to facilitate the ability to mount boards close to bike. Sorry for the lengthy input
this is a design in progress. I will need to find new surface material by the end of this year for the boards. also these were not the
shaker style boards. Krazy8s Those boards should fit any clevis mount. Originally Purchased from Dennis Kirk. Hope this Helped
Carl
05 FXDLI
Carl
05 FXDLI
The ones above look exactly like this kit for $69. They look good on there.
I love the prices at this place!
http://www.kcint2.com/product/50-240...Y-1984-UP.html
The other kit I listed is $75 which is a great price too.
OK, my 2 cents worth. I had em, " old style" they were comfy. Looked good to me, had them mounted to foward controls. Down side was they cause wear on the bushing for the foot brake. They do put more pressure on the mounting point of the foward controls. That said I liked them, but I ended up selling that setup and just buying the FXDP floorboard setup from J&P cycles. I took a test ride and I love them. I hope this helps you some. I wish I had known about this forum back then. I could have saved some money.
