How to remove electrical connector
Old 03-30-2011, 02:13 AM
DeneFXDWG's Avatar
DeneFXDWG
DeneFXDWG is offline
Default How to remove electrical connector
I am in the process of pulling my signal light wires up through the bars to install them on the forks. How do you remove the big 8 wire plastic connectors? I have found out how from others here to do the little 3 wire ones, (haven't succeeded yet), but I can't find instructions on how to take of the big ones.
Old 03-30-2011, 02:25 AM
iDodgimus's Avatar
iDodgimus
iDodgimus is offline
I don't thing you need to disconnect the big ones, the signals are only the 3 wire plugs... Sounds like you've done all you need to there bud!
Old 03-30-2011, 05:29 AM
mud's Avatar
mud
mud is online now
muderator
Received 8,771 Likes on 2,063 Posts
Molex connector poking tool.
The 06 handlebar controls used Deutsch.
In 07 they went to Molex.
Very simple to remove the wires. (pix follow)
First off you have a hook tool........
Insert the hook tool into one of the D shaped holes
and the point will aim at the other Dhole.
Above, use the tool to pull up about a quarter inch.
(you are pulling up the secondary lock)
Now, below I show a little T wrench I made up,
(for the primary lock)
using.032 stainless steel wire.......
Now, below, this is where you wanna poke your tool.
Doesn't take much, you don't need to bend anything.
Just push your tool in gently,
and pull it out the back (the wire).
All of the high performance fittings that are used these days are marked.
Whether they be AMP, Deutsch, or Molex (pictured below).
..........they are all marked...........................................
Dene, as to finding instructions, look in the stickies.
Old 03-30-2011, 09:35 AM
DeneFXDWG's Avatar
DeneFXDWG
Actually Dutch, I figured while I got it apart I'd continue on past the sig lite install and prep it for the arrival of the new drag bars so those big 8 wire ones will have to be taken apart so the wires can be threaded out through the old bars also. Can't see any little tabs on that at all.
Old 03-30-2011, 09:42 AM
DeneFXDWG's Avatar
DeneFXDWG
Default Thanks Mud
I'll fly at it shortly, never looked in the stickies.
Do you recommend replacing the connectors with new ones and are they HD specific or will most parts stores be able to get them?
Old 03-30-2011, 01:19 PM
SodFather's Avatar
SodFather
SodFather is offline
just did mine past weekend using MUD's post above. Worked great(thx Mud)
Old 03-30-2011, 02:56 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
You can get the connectors through the dealership or order online at Zanotti, Lakeshore, etc. Also, NAMZ has them online ... http://namzcustomcycleproducts.com/p...ctors.html#top
Some online or local indy shops who are distributors dealing in V-Twin will be able to get them ... you used to be able to see the electrical connectors in the V-Twin Mfg catalog and at pages 288 - 291 (in the 2010 catalog disc)
R/
'Chop
Old 03-30-2011, 09:20 PM
16VAFXDL's Avatar
16VAFXDL
16VAFXDL is offline
Just got done running my wires through new T-bars on my bike a month or so ago. There is no need to replace the connectors unless you damage them somehow. I actually used a small pair of needle nose pliers to grab the two D-shape holes and pull up the lock. Then I used a really small flat head screwdriver (like for a computer) to depress the little internal latches for each individual wire end. Make sure you draw yourself a color-coded wiring diagram before you start pulling them apart just to have as a reference for yourself. It took me several tries to make sure I put them back together correctly, but once I cracked the code, it was much easier.
DanHappy
03-11-2015 08:41 PM
Puggy
01-26-2014 05:26 PM
peddler
05-19-2012 05:56 PM
99superglide
04-02-2011 05:10 PM
amish
05-02-2008 04:36 PM
Quick Reply: How to remove electrical connector
