easy way to install billet headlamp
Hi, do somebody know how to change my headlamp from my dyna wide glide 2011 for a billet headlamp 4 1/2 in a easy way? I have a instruction document what say that i have to disconnect negative, remove fuel tank etc. is there a easier way or is it to difficult for a amateur like me?
regards from Aruba
argggg find it myself... just remove frame tube and cover, after this i disconnect connector and replace headlamp.
regards from Aruba
I have a 2" tank lift on my bike so when I did the change out I reached up under the backbone and removed the black plastic cover. You'll need to carefully pull out some of the wire harness to gain access to the headlight wiring harness. Hand-over-hand it back from the headlight. Once you've located it you'll need to pull it out a little. Be aware that my headlight wires were flip-flopped on the high and low beams. I had to take the connector apart to move the two wires into the proper position so when I hit the high beams with the high beam switch the high beams came on and not the low beams.
streeteagle
07-19-2007 09:26 PM
