Last edit by: IB Advertising
Issue: What is the best EFI tuner with no crazy modifications
When looking for a new EFI tuner there could be a lot of information out there that is difficult to wrap your head around. Users give their opinion of what is the best tuner out there that doesn't have too many bells and whistles for a decent price.
Read the full discussion below for more information
Best tuner ?
I looked into them all and went with the TTS setup very easy to use (even I sorted it out) plus any changes later you can retune, move to a different elevation retune add a big bore kit retune plus and this is what sold me on it you can dump and keep the stock map so if you sell the ride put all the stock parts on and stick the original factor map back in and its good to go,
Rev perf
I don't know anything about Tuners but I think after reading myself blind,i'm going to go with the Rev Perf EMS,every post I have read(on several forums)from people who've installed them,have had nothing but positive comments about them,might be worth checking them out,can't hurt.
To JSprad,I have the XIED's on my 07'FXD,seem to work exactly as it says on the tin,bike runs better with them than without them.
I went with a Power Commander V from FuelMoto. I told them my bike info (model, year, exhaust and A/C) and they put a custom map together for me. Bike runs great. If I had $900 I would have gotten the Thundermax, but for me I'm just messing with the air cleaner and exhaust so the PCV fits my needs.
Here is some info in this thread.
https://www.hdforums.com/forum/dyna-...max-makes.html
If you don't want to dyno tune and want the benefits of a real good tune, the ThunderMax w/autotune is the only way to go.
I had a T-Max with auto tune , and I had to replace both sensors , twice . I never felt satisfied with the performance , it popped and backfired a LOT . I even had Zippers look at the tune , and they improved it some , but the dang sensors went , again , ad it never got back to where it was . In short I was dissatisfied . Especially for the money $$$$! Honestly , if you are just going with mild upgrades , I would look at the E.J.K. (electronic jet kit) from Techlusion . Or , I read that Cobra is set to release a new Auto tune device . It looks real interesting....check it out here..I am in no way affiliated with any of these companies . Just offering my opinion.
http://www.motorcycle-superstore.com...Pro-Tuner.aspx
I went from the Techlusion to the ThunderMax w/ Auto Tune ... could not be happier ....
The TTS is the former vendor for the Screamin Eagle Race Tuner (SERT) ... predecessor to the current Screamin Eagle system ... [note: there are two SE systems ... one that is an add-on system and one that allows you to take control of the ECM and reprogram it] ....
One major distinction between TMAT and the TTS/SERT is the use of wide-band O2 sensors with ThunderMax ... it senses the oxygen content of the exhaust during the entire RPM spectrum .... Whereas the TTS uses narrow band O2 sensors and applies a computer algorithm to extrapolate the optimal AFR curve ....
I have heard good things from users of the other systems, too ....
The TMAT system retails for more... but, you can make up the savings on the money you would have spent on Dyno tuning ....
Also, you could be like me and luck into a good deal from someone who decides to go with a different system ....
R/
'Chop
R/
'Chop
